top right bell housing bolt, how do i remove?
Old May 19, 2012 | 10:17 PM
archer472's Avatar
top right bell housing bolt is the only thing holding this tranny on(and a couple of jacks) i cant get enough room to break it free, do i need a 2 ft extension or should just use power tools??
ive tried everything i can from as many extension as i can, to getting it from the top. which may be my only option just take off motor mount and drop 2-3 inches and i can take it out easy enough
the bolt im talking about is top right 14mm bell hosing bolt..
please any help is appreciated, right now im thinking of impact gun with a bunch of extensions
Old May 19, 2012 | 10:56 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: top right bell housing bolt, how do i remove?
wobble socket and 2' extension, or wrench from the top.
Old May 20, 2012 | 07:18 AM
wrench from the top
Also, if this is V8, those bolts are actually 9/16"; which even though 14mm is not the "right" size (it's smaller) it usually fits.
If it's a 6-cyl I haven't the vaguest clue what size they are.
Old May 20, 2012 | 07:32 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I have used the wrench from the top method and believe this is your best bet.
Old May 20, 2012 | 08:31 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Pull the dizzy, then get a 14mm combo, but the closed end on that bolt, then put the box end of your next larger wrench over the open end of the 14 mm. This will give enough leverage for most guys.
Old May 20, 2012 | 10:01 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
a 14mm ratcheting wrench is your best friend when it comes to tranny bolts.
Old May 20, 2012 | 12:21 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You found one that doesn't explode the first time you put 5 ft-lbs on it?
Old May 26, 2012 | 03:11 AM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
snap on takes some decent abuse for their ratchet wrenches.
Old May 26, 2012 | 08:12 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I have 2 sets that have been abused and misused for years now and never hade a problem.
For rhe OP, a really long extension, a wobble and the right socket will work just fine from below. You can lower the back.of the trans a little and you will have more room. Just be careful you don't break the dizzy cap on the firewall.
Old May 26, 2012 | 12:10 PM
87350IROC's Avatar
Car: 87' IROC
After doing it many times, I much prefer doing it from the bottom. You need about 2ft of extensions and a wobble. It also helps to lower the back of the trans a little.
I agree on the ratcheting wrenches. Easily the best tools I have bought over the basic set. I have had my Gearwrench ones for about 5 years and never had a problem with them. I have even whacked them with a mini sledge a few times and still no issues.
Old May 26, 2012 | 02:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
thats the brand i have, could not remember offhand. Great quality. And i as well have taken a hammer to them on more than a few occasions
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
3rdgenparts
Aug 8, 2015 07:09 PM
