Transmission or brakes?
Old May 25, 2012 | 08:57 AM
pies01's Avatar
I just picked up a 1992 firebird I plan on restoring/fixing up.
It will be a new experience for me.
Well today I wanted to drive it around a bit, I put it in reverse and it shifted into gear just fine.
I go to the end of the driveway and hit the brakes, the car squealed (it came from the back end) the car then stopped and no matter what I put it in (drive/reverse) the car wouldn't move.
If I shut it off and turn it back on it shifts again, until I brake then nothing.
Does this sound like more of a brake or transmission issue.
Old May 25, 2012 | 07:07 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Transmission or brakes?
Very bizarre, but probably a transmission problem.
Old May 26, 2012 | 09:45 AM
1991_RS's Avatar
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
Try shifting it into neutral & rolling it by hand. if you can't, it's very possible it's brakes. It might be the auto-adjuster hanging up.
Old May 26, 2012 | 09:51 AM
bookoorootoo's Avatar
Car: 86 z28
Engine: 305 l
Axle/Gears: 383
def brakes, prolly a drum issue "the self adjusting drum star" is tweaked, i had this prob on my maro
Old May 26, 2012 | 09:59 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Old May 26, 2012 | 11:27 AM
pies01's Avatar
Thank you so much guys, I'm going to work with the brakes today and find out more.
Old May 26, 2012 | 03:05 PM
pies01's Avatar
now it runs like it always has, my last question I guess is that I need to replace whole exhaust system.
Could the fact that it's not building up much back pressure cause it to need more gas to get it going?
I have to push the pedal down pretty far to get it going but after that it runs like normal.
But I noticed when its in drive or revers it needs gas to get moving, normally if it's in drive/reverse I let of the brake and I'm moving.
Old May 26, 2012 | 03:12 PM
Edwardgp's Avatar
Engine: 454-350
let us know what you find.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
