Which T56 bellhousing bolt does this clip go on?
Old May 21, 2012 | 09:02 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
There are six bolts for the bellhousing, when looking at the engine from the rear. Which bolt does this clip go onto, and what's it hold? I'm ready to drop the motor back in! I put the clip on bolt #2 (going from left to right) just to take the pics.
Attached Thumbnails Which T56 bellhousing bolt does this clip go on?-imag0098.jpg   Which T56 bellhousing bolt does this clip go on?-imag0099.jpg
Old May 21, 2012 | 09:33 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Which T56 bellhousing bolt does this clip go on?
there's one that goes on one of the top right two trans-to-bell bolts but I don't know if that's the one.
Old May 21, 2012 | 10:01 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Those clips normally go on both of the top 2 bolts of the trans and hold the wiring harness. On a 3rdgen anyway.
Old May 21, 2012 | 10:04 PM
Car: 89 GTA
Axle/Gears: 4.10
Of the engine to bellhousing or on the bellhousing to trans?
Old May 21, 2012 | 11:46 PM
TTOP350's Avatar
Bell to block. top 2 center bolts. The clip is bent. the 90* bend in it should be straight..
Old May 22, 2012 | 12:23 AM
Twin_Turbo's Avatar
I would not use them, they are a PITA and leaving them off will not affect anything
Old May 22, 2012 | 01:38 AM
87350IROC's Avatar
Car: 87' IROC
Not what you are talking about, but I will also add that there is a clip that goes on the upper passenger trans to bell bolt that holds the vent tube.
Old May 22, 2012 | 06:16 AM
TTOP350's Avatar
Yes,yes, listen to Obi One Kenobi, you must..
Old May 22, 2012 | 09:13 AM
Car: 89 GTA
Axle/Gears: 4.10
Thanks guys, I'll forego this clip and be sure I get the vent tube clip in place!
Old May 22, 2012 | 10:15 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
That is one clean T56!
AussiePr0nCar
Mar 6, 2020 04:04 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
jtwoods4
Sep 3, 2015 05:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
