strength of aluminum
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
I'm curious as to how much power the OE aluminum drive shafts can handle before destruction
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: strength of aluminum
Can't just put a number on it, there are too many factors. Tell us your engine, trans, weight, gearing, tires, and usage. Then we can tell you what to expect. It'll never be good for running tens, but beyond that, there's just no solid rule of thumb. If you want to run, plan on a 3"-dia. x 0.083"-wall steel shaft with 1350-series yokes.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They're not as strong as a steel shaft. An aftermarket aluminum shaft may be a bit stronger.
They stand up in the LS1 cars pretty good; so unless you're WAY past those AND you have realy sticky tires, probably not worth worrying about.
Car: 86 Camaro Z28
well there is no way I'm way past what the LS1s can do. It's pretty much like a healthy bump up. Sounds good, I just make sure before I invested and destroyed. Thank you
Car: 87' IROC
Does anyone happen to know the wall thickness of any of the factory driveshafts? If we knew that, it would be a really easy calculation.
aluminum has no endurance limit
I think that's a little bit of a .... stretch.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
From what the guys here have told me, the thirdgen alum shafts are way stronger than the LS1 aluminum shafts.
Not really...
Doesn't matter too much though. Take what you can get. Like I said, if the LS1 cars get by with em, most likely they'll work fine for most of us on here as well. Don't outsmart yourself over a bunch of "theory" type crap in cases like this; use your eyes, look around you, and just go with what works.
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
I have also heard the 4th gen shafts might have a thinner wall thickness, but
I have not confirmed.
Car: 86 Camaro Z28
I appreciate the help. there's just nothing worse than spending the money, and then braking it. If I had the money a carbon fiber one would be in the budget
Royal_Z
Sep 30, 2015 08:45 PM
