Drive shaft replacement
Old Jun 5, 2012 | 09:56 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
What do I have to do to remove my drive shaft and put in my aluminum LS1 drive shaft? Ive never messed with a drive shaft in my life.
Old Jun 6, 2012 | 12:21 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Drive shaft replacement
unbolt x 4 at the differential pinion yoke
gently leverage the u-joint away from that yoke; hang onto the u-joint cups
pull it out of the trans; hopefully you raised the rear of the car vs. the front or bought a plug
Install is the reverse of that.
Old Jun 6, 2012 | 12:48 PM
Car: 92 Camaro RS
Engine: 305 TBI
Just them x4 bolts and the driveshaft will slip out?? that seems very simple, If I wanted to put new U-joints in my used drive shaft could I use a regular C-Clamp to pop the caps off and on?
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
