I did something bad
Car: 1988 Pontiac TransAm GTA
Transmission: 5speed manual
Axle/Gears: 3:42 gears
I did something bad
So i was coming off the highway and i was going to down shift to 4th gear while i was slowing down but i had a sharp turn and wasnt paying attention and accidentally shifted to 2nd and the tires locked and chirped twice before i put the clutch back in. Everything seemed to shift alright after that but what might be the possible problems in the future?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: I did something bad
The only way too tell if you did damage would be to disassemble the t5 and look for chip teeth on the gears or countershaft. If it has been a while you could change the fluid and look for large metal debris.
Car: 1988 gta carbed 383
Engine: small block 4bbl
Axle/Gears: 3.27 g80
Car: 85 camaro z28
Engine: 355
Transmission: t-5
I did that driving in 5th gear, dropped it accidentely into 2nd, tires locked up and left a nice smoke trail from the rubber.
Was 7 months ago if i remember correctly, everything still going fine in transmission.
dimented24x7
Sep 17, 2015 06:58 AM
