NEED HELP Converting mechanical clutch to hydraulic clutch system!!
Old Jul 11, 2012 | 01:22 AM
burnoutking82's Avatar
I have a 1982 firebird that i recented put a 5 speed transmission in it that came out of a 1985 firebird. my 82 was a mechanical linkage system for the clutch. need to know if i would need to purchase a new clutch pedal to attatch the ( i think its the ) slave cylinder too or is there another piece between that and the pedal. would i be able to mount it to the firewall in the same spot where the mechanical one came thru the firewall?
Old Jul 11, 2012 | 02:21 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: NEED HELP Converting mechanical clutch to hydraulic clutch system!!
84 and newer pedals have a support brace or braces.
These are bolted down with the nuts that bolt the master-cylinder retaining u-bolt.
The master cylinders originally had a gasket on them which has the pattern of two small holes and a central large hole.
Putting these on the firewall and lining up the holes using your eyes, hands and brain shows you exactly where the hole belongs.
I think you'll find the hole is in the right place. But that process will confirm.
Old Jul 11, 2012 | 06:28 AM
What he said...
You need the entire pedal assy from a 84-up car. The clutch pedal itself is different, the length of the pivot is different, and it has the ABSOLUTELY ESSENTIAL 2 little braces.
The existing hole is in about the right place, but has to be ovalled out slightly; downward and toward the center especially, if memory serves. 2 bolt holes have to be drilled. The little gasket that comes with your brand-new hydraulics from GM can be used as the template, once you get the right location for it based off the holes in the 2 little braces.
Old Jul 11, 2012 | 09:53 AM
thx guys. Do u have any idea where i can find a assembly for that year. or do u think i can get away with modifying the one i have?
Old Jul 11, 2012 | 11:04 AM
jmd's Avatar
jmd
You could add a stud to your existing pedal.
https://www.thirdgen.org/forums/tran...pedal-mod.html
But I think later pedals had a more reliable neutral safety switch.
Or you could use an 83 bellhousing.
1992 Trans Am
May 10, 2023 07:19 PM
gta90
Sep 15, 2015 04:00 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
gwade12
Aug 8, 2015 08:17 AM
rsrmoore
Aug 7, 2015 08:44 PM
