$2000 for a trans rebuild
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
well my 700-r-4 died,wont shift out of first .the LEAST expensive quote has been $2000 for a rebuild.im seriously considering a REALLY big bonfire.i just cannot justify spending that much money for a trans.the insult was this: the trans shop will only warranty their work for...........30 days!!!! and when i asked WTF thats about .they said......well thats about as long as itll last. im thinking about a sidewalk parts sale .all my camaro stuff .gone$2000 my ***
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: $2000 for a trans rebuild
If they will only warranty it for 30 days and said thats all it will last?
Find another shop...not the cars fault..they all break sooner or later.
Keep looking.
Keep looking.
Car: check
Engine: check
Transmission: check
If all there is is 1st & reverse, pull the governor out. Likely the plastic gear is stripped, easy to replace.
RBob.
RBob.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Can you pull the transmission yourself?
What budget are you looking at?
Is your motor stock?
If you can pull it and put the replacement in yourself, look here
https://www.700r4l60e.com/store/home.php?cat=20
All of these are under $2000 (without shipping) and a lot of members on here have had them last and take a beating.
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I would check the govenor gear
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Over here bout 10 miles away from me I know the owner of a transmission shop & he says he'll charge me $750 for a rebuild on my 700R4
Engine: 5.7 TPI
Yet, only 2 miles away is another transmission rebuild place, but when you call the guy on the phone is arrogant, totally does not Instill Confidence in the customer while boasting about how their all Pro's & how you'll never find anybody else as good as them, quotes me a rough Estimate of 1,700 bucks for the rebuild but he says I have to bring it in because it could be more and It will take 2 weeks to do. While the other shop in which I know the owner will have it for me in as little as 5 working days & he does exude pride & confidence in his work & reputation. & I have 4 cars that will need a rebuild in the future so I'm taking them to the guy I know will take care of them for me.
Engine: 5.7 TPI
P.S. the shop from which I know the owner says he gives me 6 months guaranteed, while the other "PRO" gives me 30 days only
Car: 1983 Trans Am
Engine: Cross-fire Injected 305
I was quoted $1,400 to $1,800 to have my 700R4 rebuilt and that includes removal and installation along with transportation to the shop which is about 40 miles away. As others have said, I would look for another shop.
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Keep looking! I looked at over 20 shops in the columbus ohio area before i found someone that would do it for $700. Quotes ran as high as $2300! Try out in the country, they might not be advertised as well, but they will usually be a lot cheaper.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
