Where to mount trans cooler?
Old Jul 20, 2012 | 01:54 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
I have a single cooling fan setup on my radiator. The cooler I have is about 12x9". Should I mount the trans cooler directly in front of the fan or off to the side? In my state there is no front license plate required so I could remove the plate bracket for better air flow if it would help. just looking for the most efficient place to put it.
Old Jul 20, 2012 | 06:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Where to mount trans cooler?
The best place on a street car is anywhere in front of the rad.
Don't use the zip ties that go through the rad. Make up some brackets to hold the cooler in front of the rad.
Old Jul 21, 2012 | 02:58 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Like this:
Old Jul 22, 2012 | 04:02 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
looks like you used some light 90* angle bolted to the core support? I can't tell if you used support on the top. my kit came with "plumbers tape" which I was thinking of using as support for the top.
My cooler looks just like the oil cooler in the pic.
Old Jul 23, 2012 | 10:34 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Definitely mount it behind one of the grille opening in front of the radiator. This will give you good cooling and will offer protection from rocks and road debris. And yes you should mount it using a more solid means than zip ties.
Old Jul 24, 2012 | 04:27 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
I would put it in front of the fan so when stationary and things are getting hot the tranny has some cooling help from the fan as well.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
toronto formula
Nov 10, 2015 06:17 AM
TreDeClaw
Aug 14, 2015 06:58 PM
