700r4 problem after rebuild
Old Jul 22, 2012 | 01:56 PM
Project86B4Z's Avatar
Car: 85 camaro RS RIP\ 86 IROC-Z :)
Engine: 2.8 MPI V6\ carbed LO5 5.7 v8
Transmission: 700r4 auto
Axle/Gears: 3.42\ posi 3.73
Just about finished with my rebuild now except for one thing my output and input shafts won't turn by hand no matter what gear it's in. They all turning fine even with the band in while rebuilding it but now after reinstalling the servo first the governor second and third the pump i can't turn either shaft either direction. I'm worried about putting back in the car and testing it because it could ruin the engine
Old Jul 23, 2012 | 05:24 AM
Pro Built Automatics's Avatar
Re: 700r4 problem after rebuild
How much end clearance do you have? Should be .005" - .025". How much band clearance do you have? .060" - .090" cover travel. Do not install it till you resolve the problem. The shaft will turn one way easy, and the other way will be harder, but the harder way should not change when the servo in installed.
Old Jul 24, 2012 | 08:36 AM
the band not jammed up but i just dont remember this problem until i put the pump on
Old Jul 24, 2012 | 03:41 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Do you have the imput drum seated all the way down
Old Jul 25, 2012 | 08:10 AM
yeah almost directly under the valvebody that was one of my first problems when i tried to get the pump back in. im beginning to wonder if the pump is the issue
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Infested
May 22, 2018 11:56 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
formula_novice
Aug 18, 2015 08:48 PM
hokis
Aug 9, 2015 03:57 PM
