rear end identification
Old Aug 6, 2012 | 03:09 PM
neilb's Avatar
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Hello all, I'm researching posi units for my car, and was wondering if there is a easy way (such as RPO codes or VIN) to identify which rear I have in my car. I'm talking 7.5" vs 7.625", not gear ratio. My car is an '86, and as far as I know the rear is original. As I understand it the 7.625" was introduced in '86, but I want to make sure that's what I have. Is it true that the 7.625" had 28 spline axles, vs the 7.5" 26? So if I pull an axle and count the splines, I would know which rear it is right?
Thanks in advance.
Old Aug 6, 2012 | 03:25 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear end identification
Thanks in advance.
The 10-Bolt FAQ should answer your questions.
JamesC
Old Aug 6, 2012 | 03:27 PM
neilb's Avatar
I did read that, but I was still a bit unclear. I'll read it again, I may have missed something. Thanks.
Old Aug 6, 2012 | 03:36 PM
neilb's Avatar
I re-read the 10 bolt FAQ, and I think I got it now... I should have the 7.625", with 26 splines using the seriesIII carrier (I have 3.42's). This should help me lots. What's a reccomended limited slip unit for mostly street with some strip? I've been looking at the eaton's units, and the Auburn units. Any other's I should consider or avoid?
Old Aug 6, 2012 | 03:51 PM
BigDrew11886's Avatar
from what ive read eaton is the way to go!
Old Aug 6, 2012 | 04:20 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Another way to tell what you have, well at least what it was from the factory. If you look on the front side of the passenger side tube, there will be a stamping in it along with a two letter code. You will probably need to clean it off some to read it like mine. That code tells you what it came with. For example, my 83 had the code PZ, which translates to 3.23 gears, rear disc, and posi. http://sethirdgen.org/reardata.htm
Here's a link to what I am talking about.
Old Aug 6, 2012 | 05:34 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
If you still have them you can try checking your RPO? codes on the console lid or back storage door.
The best way is to pull the cover and see exactly what you have. 26 or 28 spline axles. 28 spline are factory only on 90 or 91 and newer. (Not sure of start) While there you can see if it is a factory posi, Auburn or Gov-loc etc, and what the gear ration is currently. You will know if anything has been changed out then.
Old Aug 6, 2012 | 05:35 PM
JamesC's Avatar
Eaton.
Guys, all this is covered in the FAQ.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
