rear to hold 850hp??
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
hey guys, quick question.
what are our options in place of the 10bolt? i have read the stickies but just curious what my swap out options might be. my motor should be putting out around 850hp and everything i've read says my rear will die.. quickly. is my only option one of those $2000 strange type set ups? hate to sound like an idiot but i just dont know and sorry if this is a stupid questions
Car: `86 SS / `87 SS
Re: rear to hold 850hp??
You're softening the blow since it's a turbo and running an automatic.
The usual 12 bolt, 9-inch, D60 that are available as bolt-in will work for you.
Going 3.42 since it's turbo? The stock 4L80 1-3rd will be nice!
i was thinking 3:23. i had an ls builder over to my house the other day buying some unused ls parts and thats what he suggested. he said even with those i'm still going to have a hard time finding traction. he agreed with the turbo ls/4l80e trans set up... said i was in for a big surprise when i finally get it all done
i cant wait Moderator
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My 9" survives just fine but I launch a lot harder than you will with the turbo.
As mentioned above, for a direct bolt in diff without changing the rear suspension to a different style, the aftermarket choices are 9", 12 bolt or Dana 60. There is no inexpensive diff choice when you need something to handle the power.
If you have enough money to build a high HP engine, you also need to spend money for a diff and tranny to handle that power.
would either of you have a referral,brand, dealer etc. for where i should get one from?
Moser Engineering sells the Wavetrac differential for the 9 inch and the 12 bolt. This is the strongest differential available anywhere. If you want something that will hold up to huge power and work well on the street then this is what I recommend. Moser makes a very good 12 bolt that is much stronger than the Chevy 12 bolt, and their 9 inch is also very strong. Look into it and see if it fits your needs.
Car: 87 IROC L98
Unless you do a lot of modifications to change the rear suspension to ladder bars or 4-link, you're going to be stuck with an aftermarket direct bolt in diff.
There are junkyard choices including the ford 8.8 but all the junkyard diffs are not an easy swap. With lots of power, you don't want some shabby slapped together fabrication just to use the torque arm.
About the cheapest route you can go is to buy a 9" housing package. It will include the bolt in housing and axles. You'll probably upgrade right to 35 spline axles. You'll then need to provide your own center section and brakes to complete the diff which you may pick up locally for a lot less. That means finding a 3.25" side bearing center section (won't be OEM). Posi/spool etc for 35 spline axles. Some sort of aftermarket disk brakes.
Lots of good deals on new or slightly used parts off Ebay that will fit a 9" and they're a lot cheaper than 12 bolt or D60 stuff.
thanks alky always an honor getting your advice.
you know my build
i cant wait
i cant wait
i'm hoping to
thanks
thanks
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Either the 9" or 12 bolt with good parts will handle 850hp without much of a problem. Dana 60 is an option, but weighs more than the other two.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I am gonna try a strange 12 bolt with 33 splines and truetrac worm gear diff with a set of 3.08-3.31's on my car and looking for 1000 hp. Wont be stressin it since no tbrake and the launches will be soft on footbrake and low stall speed. Never killed the 10 bolt with 800-ish hp so i fear nothing with a 12 bolt haha
Considered wavetrac but too expensive for me as i need 35 spline axles as well to get it to work
Car: 91 Camaro RS
Engine: 6.0 lq9 ls bored to 408
Transmission: T56 6 speed
Axle/Gears: strange s60 4.10 with a spool
i have a strange s 60 in mine. it is extremely stout piece. just laughs at my 5500 rpm clutch dumps with a stage 3 clutch. i have 426 rwtq so not nearly as much as you do. when i bought it it was to be capable of 800 hp and the guy i bought it from said it would be right at home behind 1000 plus. it is heavier. i gained about 60-70 pounds from my 10 bolt. so not the end of the world. personally i would take an extra 60-70 pounds for the durability of the rear end, they also say they are a bit more efficient so that could make up for some of the weight. havnt had it dyno tested since i installed it though.
price is not to bad either they can be had brand new for a bit less than a 12 bolt or a 9 inch.
just my .02 cents
just my .02 cents
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
I'm thinking about buying a fabricated 9" rear end from these guys.$2,750 shipped with a torque arm. They have Wavetrac differential in either 31 or 33 spline for an extra $800. That is what I will be going with too. Some people report having problems with Moser rears being noisy. Really good reviews for these guys from 4th gen people.
http://www.midwestchassis.com/fabricated-9-specs.html
Car: 91 Camaro RS
My s60 is a bit loud on the coast side of the gear. I'm told they all do that. Midwest rears are very good rear ends. I would get the backbracw option on it. And atleast 33 spline axles. The s60 comes with 35 spline stock.
thanks for the tip i'll check them out.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
