Th700r4 overhaul --> need your opinion...
Old Aug 19, 2012 | 08:19 AM
Camaro71's Avatar
Hi,
working on my first Th700 and need some input from 'those who know'... The reverse input drum shows wera in the middle (see pics). When checking with a feeler gauge it's up to (most places less than) 0.005" gap.
The ATSG manual only mentions to check for straightness and doesn't mention any tolerances...is this drum usable or shot???
The band shows wear in the middle and less/bo wear on the outside, makes me wonder if this could be caused by improper apply pin length?
Thanks for any help.
Old Aug 19, 2012 | 09:02 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: Th700r4 overhaul --> need your opinion...
that is normal to happen on those drums. better safe to get a new one than chance using that one especially if using the extra wide band. we throw those away were i work. we don't allow any gap in the straight edge under the band surface. pin length has nothing to do with it. if the pin were to long it would bind the drum and if it were to short it would burn it up all the way across.
Old Aug 19, 2012 | 09:09 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Great information 87zjeff, When I start on 4l60e would you be available for a few questions?
Old Aug 19, 2012 | 09:19 AM
87zjeff's Avatar
will be glad to help as i can. just be aware that i work in reman of transmission parts and not actual rebuild. i have built a few 700r4's for myself and friends. i can also help with parts interchange. if it comes to troubleshooting one, i'll help as i can but others such as Dana would most likely be a better source as he has built lots of these.
Old Aug 19, 2012 | 09:24 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
They can be reconditionedz(made flat again). Just by looking i'd ay the center of the band smoked because the surface wasnt flat. She's holding on the sides tho..
Old Aug 19, 2012 | 12:53 PM
87zjeff's Avatar
yes, they can be machined to be made flat again, but then you have to worry about adjusting the pin to engage the band properly. you can't machine them and put them back in without adjusting the pin.
Old Aug 19, 2012 | 01:06 PM
Camaro71's Avatar
Well this happened to be exactly my second Q:
Is there an alternative to check the pin length without the KentMoore tool I don't have?
Thanks for such fast answers!
Old Aug 19, 2012 | 04:27 PM
87zjeff's Avatar
i don't use the tool. every time i have it has burnt the band. i go by feel. the atsg manual did have a measurement for band travel but i don't know what it is.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Cleotiz
Jan 6, 2018 08:56 PM
camaronils
Sep 20, 2015 02:57 PM
Out-Cast
Aug 17, 2015 10:57 AM
JETHROIROC
Oct 10, 2000 09:22 PM
