TH700R4 reverse SLAM
Old Aug 24, 2012 | 06:58 PM
bookoorootoo's Avatar
Car: 86 z28
Engine: 305 l
Axle/Gears: 383
rebuilt TH400R4 30k miles slams hard like its about to rip off from the car...any suggestions? all else is good besides sometimes it floats from 2nd to 3rd and will tach out at WOT on OD from 3rd to 4th w/o gaining speed >.< will work fine in D tho
Old Aug 24, 2012 | 08:10 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: TH700R4 reverse SLAM
Check fluid level & color.
If it's still red and doesn't smell " burnt " I would get a trans filter kit--
Filter & pan gasket and pull the pan looking for obvious signs of gear shavings in the pan.
If its good, replace the filter since it only takes a few minutes anyway.
Top off the fluid level.
At least you would know if its on a path of self destruction.
Old Aug 25, 2012 | 12:42 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Do you forget the reverse check ball in the case.
F-body driver
Mar 6, 2023 11:44 AM
Veaceonee
Sep 29, 2016 08:15 PM
nova983
European Region
Nov 2, 2015 12:15 PM
camaronils
Sep 20, 2015 02:57 PM
84redta
Sep 19, 2015 09:58 AM
