Burnout help
Old Aug 26, 2012 | 12:07 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
Burnout help
One of my buddies with a thirdgen was asking abiut me doing a burnout, so i tried. my wheels wouldn't spin and the tach stopped at 2000 rpms and would just hold there. New engine has 30,000 miles and new trany has 24,000 so is there something im missing in the equation?
Old Aug 26, 2012 | 12:13 PM
Jason C. Laney's Avatar
Car: '90 rs
Engine: 305 tbi for now
Axle/Gears: stock rear for now
Re: Burnout help
is motor pretty much stock, or built? takes a little power to turn 3.23's, stock motor may not do it. plus, it also means that back brakes might be working real well. remember, when power braking, rear brakes are engaged as well as rear.
Old Aug 26, 2012 | 12:32 PM
Dabesiv's Avatar
Re: Burnout help
I snapped a cam on the stock 305 so its the GM Goodwrench 350 with roughly 280 HP around 100 more than original but the engine is all original from the crate if that's what you meant. My buddy has the '92 RS with a 305 and could spin his but I'm sure we have a different ratio in the rear.
Old Aug 26, 2012 | 12:46 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Burnout help
You wont have to buy tires as often as your bro.
Old Aug 26, 2012 | 12:52 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: Burnout help
Hmmm... Mine is pretty much stock, not even running as well as it should, and I can still spin my tires...
Old Aug 26, 2012 | 12:54 PM
Dabesiv's Avatar
Re: Burnout help
haha thats obvious, but just to for some fun it'd be nice to smoke him out a bit.i guess maybe a line lock is the only way to go unless i change the rear gears
Old Aug 26, 2012 | 12:57 PM
Dabesiv's Avatar
Re: Burnout help
Im more or less concerned with the engine not actually going up in RPMs, i can't even get a good chirp of the tires since its not going too high
Old Aug 26, 2012 | 01:26 PM
Edwardgp's Avatar
Engine: 454-350
Re: Burnout help
I guess you could line lock it if you have that desire bad enough.
Old Aug 26, 2012 | 02:06 PM
Dabesiv's Avatar
Re: Burnout help
i think its one of the things that atm it sounds good but after thinking about it its just pointless
Abubaca
Nov 5, 2016 12:22 PM
Thirdgen89GTA
Apr 11, 2016 02:07 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Cleotiz
Sep 16, 2015 08:02 AM
Amillionoh7
Sep 5, 2015 11:44 PM
