t56 swap
Old Aug 26, 2012 | 10:07 PM
transamws6's Avatar
Car: 92 trans am ws6
Axle/Gears: 3.42 ls1 rear end posi
t56 swap
i just wana thank everyone ...my t56 swap went good now my 92 is a 6 speed...for those that wana do it..go for it best project ive done to a third gen so far..
Old Aug 26, 2012 | 11:19 PM
chickenbalLS's Avatar
Car: 88 bird
Engine: 305 soon to be ls
Transmission: t56
Re: t56 swap
Yep I love mine I put in a tremec retro fit close ratio one!!
Old Aug 26, 2012 | 11:36 PM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
Transmission: T 56 (converted from 700r4)
Axle/Gears: 4.10 from a 2000 TA
Re: t56 swap
Hey guys I'm in the middle of one right now. What did you do about the pedals. I have a brand new fourth gen master /slave set up. I got it bolted up but the master eye hole doesn't seem to fit my third gen pedals ( little nub thing my old master hooked on to
Thanks in advance
Old Aug 26, 2012 | 11:50 PM
Car: 88 bird
Transmission: t56
Re: t56 swap
I do believe you need a 4th gen pedal assembly, I was already 5 speed...
Old Aug 26, 2012 | 11:53 PM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
Re: t56 swap
Ya I've read both can work and also of people cutting and threading their master. Seems like it should fit length wise but it just won't get on there. Before I start grinding and drilling I thought I'd ask what you Guys did
Old Aug 27, 2012 | 12:03 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: t56 swap
Thanks in advance
You just need to ream out the bushing, a dremel or die grinder will make quick work of it.
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: t56 swap
Thanks in advance
I used a fourth gen master and 3rd gen pedals (There ARE benefits to 3rd gen pedals) so I know what you're talkinga bout. If you decide to make your master cylinder adjustable, you can use a t5 master cylinder rod eyelet and mate that to the T56 master. Problem solved and it even looks very nice.
What I did though, was I got a T5/thirdgen pedal bushing, and I trimmed it up to just float inside the eyelet. Not really as pretty as I would have hoped since it attaches so much differently, I had to really mangle it, but it's in there now and the clip along with the eyelet itself keeps it captive inside there and it does what it needs to do - it takes up the extra slack and offers a plastic bushing/cushion to the assembly. They're cheap, so go buy one and just trim the "clips" on it, because they're no longer useful, and use it just as a captive bushing, similar to the way the T56 bushings were to begin with.
Or you could drill it out, but I didnt have much luck trying that. I cant remember exactly why, but I think it just disintegrated on me and fell apart.
Old Aug 27, 2012 | 12:04 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: t56 swap
Wait, do you mean where the end of the pushrod goes onto the pedal, or the U bolt that holds the master to the firewall ?
Old Aug 27, 2012 | 12:09 AM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
Re: t56 swap
Where the end of the push rod goes onto the pedal
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: t56 swap
Yep, ream to fit.
Old Aug 27, 2012 | 12:16 AM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
Re: t56 swap
Cool I'll try that thanks
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
