Starter for t5 ???
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Starter for t5 ???
(355 tpi 2 piece rear main seal block) Ok so got a couple quick question ??? Im in the middle of swapping out my auto 700r4 to the 89 wc t5 an i got the starter off the parts car but now it doesnt want to work just clicks so i swapped the solenoids from the auto one an it still just clicked ???? But the auto starter worked perfectly fine can i reuse the auto starter with the t5 or do i have to get a t5 starter with the 153 tooth manual flywheel that is on now Or can i just use the auto starter that worked with the 168 tooth flexplate ????
Car: `86 SS / `87 SS
Re: Starter for t5 ???
There is a larger L98/auto starter in third gens that doesn't fit the T5 bellhousing.
There's a smaller one with the 305s that does fit.
This thread answers every single question you have, directly or indirectly and goes over more detail about what I just typed above:
https://www.thirdgen.org/forums/tran...tarter-vs.html
Gunner242
Dec 25, 2015 04:49 PM
