700R4 Shift Linkage?
Old Sep 12, 2012 | 01:19 AM
vyserage's Avatar
So im looking to replace my transmission shift linkage, whatever that is. Can somebody please do the following:
1. Tell me what this is and what it controls.
2. Tell me its official name so i can look it up at autozone.
3. Tell me the symptoms of a bad cable and what happends when it starts getting bound up (which is what my friend said it was doing in the past).
I would greatly appreciate it! Tyvm
This is for a: 1990 Pontaic Firebird 3.1L V6
Old Sep 13, 2012 | 05:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 700R4 Shift Linkage?
Which trans cable are you referring to ?
Shift linkage would be what goes between shifter and trans ; you use to select the gears ;P/N/ D
Throttle valve cable (TV cable ) goes between the engine and trans and is what controls the gear shifts.
Old Sep 13, 2012 | 06:46 AM
vyserage's Avatar
Ya the first one. I already know of the TV cable and am going to replace that since it doesnt seem to be working correctly with a newly rebuilt transmission. However in the past my friend was saying the "Linkage" was getting bound up and so im wondering whats the effects of a "bound" or "bad" linkage. I know of 1 problem i have right now which is i cant manualy shift into 1st gear, its like jammed. This is an automatic transmission so just putting it in Drive is fine, and 1st gear works flawlessly, and its a new rebuilt trans so im 100% positive its not a transmission problem, so im trying to figure out why i cant manualy goto 1st gear. 2nd and up works just fine.
Old Sep 13, 2012 | 09:54 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Maybe the shift cable just needs adjustment where it bolts to the tranny shift arm. The arm has a slotted hole iirc which allows for a bit of adjustment. You'll need to do this adjustment anyway if you buy a new shift cable, so might as well try on your current one. If it's not damaged, you should be able to get it to a position where it goes into both 1st and park ok (opposite ends of travel).
You might have some difficulty finding a new shift cable, GM has discontinued them. There are a couple of aftermarket ones, but have a bad rep for breaking easily. The consensus seems to be get a good OEM one from a jy if you can.
Old Sep 14, 2012 | 06:56 PM
vyserage's Avatar
Thank you, this has given me enough info to find the cable i needed on ebay for around $30.00
Old Sep 15, 2012 | 07:17 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Do it soon ( like before you drive the car again
a non working or incorrectly adjusted TV cable can make your nice new trans burn up real fast
Old Sep 15, 2012 | 11:11 AM
vyserage's Avatar
see thats what i keep telling my dad since he's the one using the car to goto work and back every day! But he wont believe me, he wants to believe the mechanic that told him it wont hurt it.
Basicly the trans doesnt shift correctly when you punch it, it just bogs down on gas and switches when it feels like it. Its a bad TV cable im sure since its doing exactly what my last transmission did before it got so much worse which is why i had to replace the tranny. So now im positive its a bad TV cable.
Luckily my dad only drives it in town and goes easy cause going on longer trips or highway is when it can get bad since its not changing correctly.
Old Sep 15, 2012 | 11:29 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Just want to second what vette said and make you fix this asap, before you damage it, if it's not already. Tell dad to stop driving it RIGHT NOW, until you make the adjustment. Which takes a couple minutes if the tv cables is ok.
This is way more important than the shifter cable. Also get a new mechanic.
Here is a site thats usually used as a reference around here:
http://www.tvmadeez.com/
Read the TV101 section. It's long, wordy, and informative.
Old Sep 16, 2012 | 05:45 AM
vyserage's Avatar
I wish it were that simple. My dad paid for the new rebuilt transmission and i told him multiple times he's going to ruin it just like how the old one went out. He doesnt want to believe me so when i get the new cable next month and have it installed, if its already ruined, i simply wont pay him back for the 500 bucks he spent plus the 200 to have it put back in the car. Seeing as how i would have to pay that money out to have it done AGAIN. So thanks everyone for the great info and i only hope next month when the cables put in, its not too late.
He only drives it in town and goes very easy on it and probly never exceeds 40 mph. Could this still mess it up?
Old Sep 16, 2012 | 06:32 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
YES..
The Throttle Valve cable is the most important cable on the transmission.. When adjusted properly it will allow the transmission to shift properly, If not adjusted right it will help destroy a transmission. Another user already posted the link to help adjust it.. Follow it.. Only takes a few seconds.. You won't regret it afterwards if it is adjusted right..
Old Sep 16, 2012 | 07:58 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
The various clutches, and band, requires adequate hydraulic line pressure to keep them engaged. The pressure required to do this increases with rpm amd load, thus the tv valve is used to provide this regulation. More throttle = higher pressure - firmer engagement.
If the tv valve is not producing adequate line pressure, clutches and band will slip continuously, and burn out. Just like you can burn the clutch out in a manual, by dumping it on too many burnouts.
If you have the situation where it's upshifting too early, and the shifts are sloppy, it won't last long. Not even doodling around town. What's the arguement? It's an almost idiotically simple quick adjustment, and will save tons of cash. Go do it yourself. In fact, it's something the mechanic who replaced the tranny should have done at the time.
Old Sep 16, 2012 | 08:32 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Very good information.
Old Sep 16, 2012 | 01:05 PM
vyserage's Avatar
Its not shifting early or late, its shifting fine. However it simply wont kick down if you try to floor it to pass somebody up, it just eats gas and changes gears at the same time it would had you been just crusing around, so around 2-3k rpm i think. I sappose this means its still not too late to fix the issue. Unfortunately as i said, my dad isnt going to stop driving it to work and back even if i tell him he's going to ruin that transmission as everybody on here couldnt be wrong.
I will try searing it into his old brain and make him believe that if he doesnt go and get a new TV cable and have it installed or bring it to me so i can install it, then im not going to pay him back for the $700 he has invested in it.
Old Sep 16, 2012 | 03:23 PM
vyserage's Avatar
found out today that he's only driving it about once a week cause it has no insurance on it haha. once a week is definately better then every day.
Old Sep 17, 2012 | 02:33 AM
vyserage's Avatar
The TV cable has been ordered and is on its way. Should be here as soon as tomorrow (Tuesday) or next week on Monday. Time to read up on the TV cable 101 so i can install it when it gets here.
Old Sep 17, 2012 | 03:12 AM
vyserage's Avatar
Ok! I have fully read the tv cable 101 and think i fully understand how to set it up. So correct me if im wrong, but heres what ill do right?
1. Install the end of tv cable into transmission where that little hook is, and screw it in (the 6mm bolt).
2. Connect the front of the cable up the top of engine where it latches in.
3. Connect the eyedrop plastic piece to the throttle area.
4. Press the "D" looking button and push the cable in towards the transmission as much as possible until it no longer goes in anymore.
5. Release "D" button, go inside the car and push petal to fully open.
Then thats it? Of course before i connect it im going to test to be sure the pedal fully open and another person at the engine isnt able to open it further, which would mean i need to fix that before anything.
Old Sep 17, 2012 | 12:38 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Yep, thats it.
Old Sep 18, 2012 | 11:29 PM
vyserage's Avatar
Yep, thats it.
Awesome, then ill do so on saterday when the cable arrives. Thank you everyone for all the great info and tips, i now know even more about the car i love most.
Old Sep 18, 2012 | 11:36 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Just a word of caution, the aftermarket cables are very fragile at the bottom where the plastic sleeve goes around the cable where it attaches to the transmission. I broke the aftermarket one trying to install it in a hurry. The factory one is discontinued but I was able to source one at the Chevrolet dealership in Guam and ordered it. There may be one more as they said they thought there was one extra. You will pay a lot but you get what you pay for.
Old Sep 19, 2012 | 12:39 AM
vyserage's Avatar
I see, i will be very carefull with that part. Thank you very much for the info
Old Sep 20, 2012 | 11:28 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Pretty much. I just hold the button in, push the cable towards the windshield. Let go of the button.... Instead of pushing the gas pedal, just turn the throttle bracket where the cable is hooked on. Rotate the bracket to WOT. You'll hear it ratchet into place. Let go of the throttle bracket and you're done.
Old Sep 24, 2012 | 09:38 PM
vyserage's Avatar
Yep, thats it.
Ok everything has been installed and i took it on a couple test runs. Something still seems a bit off. Its kicking down fine when i floor it and stays in lower gear when flooring it till around 4k rpm then switches. Driving normaly/easily and it switches around 2k rpm up till overdrive. Does this sound about right?
Also i noticed that when i set the TV cable, it didnt click at all when my friend pushed the petal all the way down, it just pulled the cable out and back in when he got off throttle. Seems like it didnt set anything. Also when he took the old tv cable out, is the little hook sapposed to retract back into the transmission or just hang there where you can very easily grab it with fingers and hook it onto the new tv cable?
Cause it didnt retract back into the transmission at all, so could this mean the valve body was never rebuilt and is wore out hence why its not retracting the hook? This trans that i got was a rebuilt trans for $450 and i gave them my old one.
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
indygene
Sep 26, 2015 11:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
