Factory Up **** Light Question Slush to Stick
Old Sep 28, 2012 | 06:00 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
This might be wrong section but its trans related
Im swapping slush to stick
i know upshift light is controled by ecm on manual trans prom in thirdgen?
im going to use a corvette tune with manual trans woundering if upshift light will work once i plug up bulb to gauges or there more than that like wiring etc ?
Thank You!
Old Sep 28, 2012 | 06:37 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Factory Up **** Light Question Slush to Stick
You may have to install the wire in the guage cluster, I did on my T/A
Old Sep 28, 2012 | 08:44 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Wire connecting light bulb to rpm activated switch like this and I assume switch is connected to vss ?
http://www.summitracing.com/parts/SUM-830449-1/
I was thinking about this but wasn't sure if I was on the right track
Old Sep 29, 2012 | 07:57 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I wouldn't worry about it.
If you are thinking the light is going to help you power shift like an aftermarket shift light, it won't.
First, it's not an Upshift light. I know it's an up arrow, but it actually comes on when you need to down shift too. All it tells you is "you would be getting better gas mileage if you were in a Different ( doesn't indicate if it is lower or higher) gear"
As you are accelerating, it comes on long before you should shift up.
It's not a performance tool, just a stupid CAFE thing
The only thing it's good for is if you are cruising at slow highway speeds, it will tell you if you would get better mileage in 4th or 5th
All American car manual shift lights are like this.
Old Sep 29, 2012 | 09:33 AM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
I believe you can set the "on" rpm in the bin though. I might be mistaken. Either way an aftermarket light would be far more accurate.
Engine: 305 to 350
Axle/Gears: 10 Bolt
That's why I hook up light to rpm activated switch like I posted above so you can use it as a performance shift light but it's a factory look
Due to The fact I'm using factory light and not a external light source
I know the purpose of the light
Like posted above the link to rpm switch
Old Sep 29, 2012 | 09:36 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea wasn't sureabout that either but I'm just going to try rpm switch and see how it works
I know aftermarket light is easier but want to keep factory look as much as possible that's last resort I guess lol
Old Sep 29, 2012 | 10:13 AM
Dyno Don's Avatar
It comes on with a preset RPM when there is no load.
This can be set in the prom.
Old Sep 29, 2012 | 10:14 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Roger that
Vintageracer
Jan 10, 2020 05:33 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
