viper t56 trans to bbc third gen
Old Sep 30, 2012 | 11:03 PM
daniel92345z28's Avatar
Car: 82 camaro z28
Engine: gen 6 454 carburated and cammed
Transmission: ls1 t56 trans
Axle/Gears: currie f9 with 3.70 gears
here are some pics for starters.but since i already had a ls1 t56 in my car i dont see it been to hard of a conversion.things i notice that are going to be different are shifter location is further ,input shaft were the pilot bearing goes is larger,gonna need a different driveshaft .and gonna need to use castrol syntorg lt oil vs dexron 3
Old Oct 1, 2012 | 12:20 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: viper t56 trans to bbc third gen
Wouldnt it be easier to just bolt on the f-body tailshaft?
Old Oct 1, 2012 | 12:54 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Doubt it, being that the F body T56 location is further rearward than the thirdgen shift hole, this one is probably going to end up in a better spot.
Old Oct 1, 2012 | 01:18 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
A cost analysis would be helpful.
The hybrid trans. build would be machining + parts.
Divorced torque arm (if applicable) and driveline shortening (instead of just yoke change)
Shifter position. Trans. mount location.
Lots of details. What I'd do wouldn't be necessarily what the OP would do.
Old Oct 1, 2012 | 10:49 AM
Car: 82 camaro z28
im gonna be making my own crossmember with a torgue arm mount.so that take cares of that problem.the driveshaft will need to be shorten but i aready have a driveshaft 1350 yokes on both ends.viper yoke will go on one end and the yoke will go on the diff.
http://www.dennysdriveshaft.com/p105...7_splines.html
getting rid of the smaller /weaker u joints
as terring into the trans is a no go unless i really neeed to.trans only has 4000 original miles on it since the car was wrecked
Old Oct 1, 2012 | 10:54 AM
Car: 82 camaro z28
but here a pic of the ls1 t56 trans looked like vs the viper trans .
Old Oct 1, 2012 | 11:43 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Is the front plate the same ?
Old Oct 1, 2012 | 01:18 PM
jmd's Avatar
jmd
Almost. The slave cylinder holes are different size and location.
Old Oct 8, 2012 | 05:34 PM
Car: 82 camaro z28
this thing should have been in a week ago.still waiting on a custom pilot bearing
Old Nov 2, 2012 | 11:56 PM
Car: 82 camaro z28
finally got to working on the car.it seems that the shifter location sit quite a bit further than before .
the viper adapter pilot bearing is the shorter one with the larger hole
and the other one is used when using a adapter plate whit a ls1 t56 trans on a sbc/bbc
Old Nov 3, 2012 | 12:05 AM
Car: 82 camaro z28
ill just be busting out the tin snips to cut the hole,and gonna start to make my own trans crossmember with torgue arm mount and shorten the driveshaft.
Old Nov 3, 2012 | 12:35 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Is that hole from T5, or a previous T56 install ?
Old Nov 3, 2012 | 11:06 AM
Car: 82 camaro z28
previous ls1\t56 trans that i had in it.with the bbc
Old Nov 3, 2012 | 11:12 AM
Car: 82 camaro z28
this is what the adapter plate looks like
metal that i used to make the crossmeber 3/8 thick steel and angle steel
Old Jan 5, 2013 | 07:18 PM
Car: 82 camaro z28
just got done with the install ,things i had to do
make my own cross member with torgeu arm provision
shorten the driveshaft . had a new one made using 1350 u jouints all the way through.
pics of what i did.
first couple of pics are of the left, a factory lenght driveshaft and the right a factory ds that i had shorten for the bbc/ls1 t56 and not pictured was the new one for the viper t56 with was even shorter.
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
