Need a posi unit! Suggestions?
Old Oct 1, 2012 | 01:33 PM
wiz56's Avatar
Car: 84 Pontiac Firebird Trans Am
Engine: 305 "G"
Axle/Gears: Stock
So I am currently work on my 87 firebird. Took the rear end cover off the other day and removed the carrier to find out it is useless. All the gears are chewed up and theres practically no more oil grooves.
What I need now is a new posi unit but I am unable to find one online for my particular rear end.
10bolt
7.5inch
28spline axles.
Any help would be greatly appreciated!!
Old Oct 1, 2012 | 08:18 PM
Re: Need a posi unit! Suggestions?
http://www.summitracing.com/parts/ETN-19599-010/
Old Oct 2, 2012 | 07:08 AM
big gear head's Avatar
Unless you swapped the axles you will have 26 splines. If you have 26 splines then I recommend the 28 spline upgrade. The Eaton Posi or Yukon Dura Grip would be my suggestions. You can get a better price than that Summit price, especially on the Dura Grip. Check ebay or www.jdrace.com The 28 spline unit is probably going to be listed as a 7 5/8 , 7.6 or 7.625.
Old Oct 2, 2012 | 09:45 AM
wiz56's Avatar
Engine: 305 "G"
Axle/Gears: Stock
i found the same item as sofakingdom at this website (http://www.drivetrainamerica.com/p-7...pline-lsd.aspx)
I have counted the axles many times and gotten the same number. 28
Old Oct 2, 2012 | 09:51 AM
Steven6282's Avatar
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
This is the one I used in my rear after some suggestions from others that I had talked to.
http://www.summitracing.com/parts/DTL-912A317/
Not sure on the differences betweeen that one and the Eaton Torque, but it's cheaper, and from what I've been told it's better for a non drag car.
Old Oct 4, 2012 | 02:43 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I run the Eaton Posi. that has been suggested along with a L.P.W Ultimate support cover.Both highly recommended.
Old Oct 19, 2012 | 10:31 AM
wiz56's Avatar
Engine: 305 "G"
Axle/Gears: Stock
Looks like a nice setup. Ive been reading good things about the covers and ill probably end up getting one with the new posi unit.
Old Oct 19, 2012 | 04:05 PM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
I have a lightly used Detroit Locker for a 28 spline 7.625 10 bolt that I may be convinced to part with for the right money if your interested.
F-body driver
Mar 6, 2023 11:44 AM
djmarch
Sep 13, 2015 01:35 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
toyotekk
Sep 7, 2015 06:36 PM
toyotekk
Sep 6, 2015 02:21 PM
