Removing Torque Arm From 91 Camaro
Old Oct 20, 2012 | 01:12 PM
Electro Panda's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 327 sbc
Transmission: 400 turbo with Shift Kit
Hey it's not a bad day in Indiana but cold haha. Time to get some tools out and work Question is How do I remove the Torque arm on a 91 Camaro from the rear end? I took off the two bottom nuts off but where do I go from there?
Old Oct 20, 2012 | 02:05 PM
Re: Removing Torque Arm From 91 Camaro
Step 0: figure out WHY you are thinking you need to take it out. More than likely, you don't.
Step 1: jack the car up by the chassis until the rear end is hanging with the wheels about 3 - 4 inches off the ground.
Step 2: Support the chassis, right where the chassis end of the rear LCAs bolts to it, on jack stands.
Step 3: put your floor jack under the pumpkin, and jack it up just enough to lift the rear off the shocks; maybe an inch or 2 at most.
Step 4: support the rear with 2 jsck stands under the axle tubes. Not, under the shock brackets; not, under the sway bar brackets; not, under the spring perches; not, anywhere else except under the axle tubes.
Step 5: re-consider why it is you are thinking you need to remove it in the first place, since now, it's easy to position it to wherever you want it to hang out.
Old Oct 20, 2012 | 03:19 PM
Engine: 327 sbc
I am noticing that most people on this forum are smart *** people.. I needed to remove it because When I put my engine back into my CamaroI forgot to reattach my Torque Arm to the tail of my transmission. Question was about how to remove it. *Update* (Rear End) Remove bottom bolts and use a hammer to tap out the bolts. Probably will have to pry the Torque Arm a bit to remove it. No bad at all. I thought there was more to it Hope this helps anyone who are clueless.
Old Oct 20, 2012 | 03:32 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You could of also unbolted the cover to the front of the TQ arm bracket and done it that way.
Sofa is a tad coarse with his responses but is correct 90% of the time..
Old Oct 20, 2012 | 04:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The above instructions are the proper way to do it. The diff needs to drop down to allow enough room for the bolts to come out the top. When the torque arm is removed, the pinion will want to rotate upward making it difficult to reinstall the torque arm.
Old Oct 20, 2012 | 05:57 PM
Right: exactly as I thought.
You don't "have to" remove the torque arm for that. If you do as I describe, you can curl your little figer around it and set it right into place in its little bracket thing, whatever form your swap-in took, with EVERYTHING else still bolted up normally.
No sense in doing any extra work, eh??
Old Oct 20, 2012 | 06:24 PM
Engine: 327 sbc
It does shift whenever you take it off from the rear and It wasn't crazy hard but we learn from trial and error lol
Old Oct 20, 2012 | 07:03 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Where in indiana are you? Btw welcome
Old Oct 20, 2012 | 08:17 PM
Engine: 327 sbc
Delaware county
Old Oct 20, 2012 | 09:10 PM
Engine: L31 350
Originally Posted by Electro Panda
Delaware county
ah, next county over. It hasn't been too cold but I also have a garage to work in. Although sometimes my garage is colder than outside
Old Oct 20, 2012 | 09:16 PM
Engine: 327 sbc
Yea haha Built my car in my driveway. From a block to a full car
Old Oct 20, 2012 | 10:41 PM
Engine: L31 350
sweet, sucks that you have to do all your work outside but still sweet that you did all that, anyways welcome to TGO, i like seeing other indiana people join
Old Oct 20, 2012 | 11:18 PM
Engine: 327 sbc
Yea lol and thanks. I love working on cars and No matter rain or sunshine I'm outside getting it done. All I need done now is exhaust and some rust work and possible turbo setup later on.
Vintageracer
Jan 10, 2020 05:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
3rdgenparts
Aug 8, 2015 07:09 PM
