Detent/Tv cable proper adjustment.
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
Im getting pissed lol. I just rebuilt my engine and swapped it back to a carb from throttle body. So why cant I seem to get this shifting right. I know the detent cable controls the pressure in the lines which can make it shift sooner or later.
Im having issues with this whole entire thing can someone please tell me an easy way to do this so I dont mess my trans up. I know you push the little plunger down to adjust it but what are the steps I take.
Any help would be great thanks a lot!
Re: Detent/Tv cable proper adjustment.
I don't know if the lines messed up or im just not doing it right. Do I push the plunger down and pull it all the way back? It seems WAY to tight when I do that... Im having trouble finding that happy medium.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You push it all the way back and then open the throttle full so the cable is pulled out the correct distance
See
http://sethirdgen.org/tvcable.htm
See
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
What carb are you using, & do you have the geometry corrector?
www.tvmadeez.com
Read the "TV 101 Article"
If your carb isn't properly equipped yet, they will have what you need
What if my cable doesn't "ratchet" out? It seems like im going to break something do I have to use some force for this?
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Yes. You will think it is about to break. Then it will "pop" out. It aint a smooth ratchet motion like you might think. You wont break anything.
If it is connected properly, just open the throttle by hand all the way. It will go. Always worked for me.
YEAHHHHHHHHHHHHHH!!!! I got it.. such a great feeling to feel it shift. I can drive my car now thanks for all the help!
TMZIrocZ350
Oct 7, 2015 12:09 PM
