Semi High RPM shift issues retrofit t56
Car: 1992 Z28
Engine: 434 CI
84 camaro with a retrofit T56 (uses stock hydralics/slave/clutch etc..). I upgraded to a centerforce dual friction clutch. cars shifts perfect at below 5500 rpms , over 5500 ish it will not shift without waiting it out or pumping clutch a few times, it will come out of gear but not go back into another...crazy problem ..PLEASE HELP!!!!!. Motor is big HP 434 stroker
