Chuck84TA
close
It grinds... Big time... So bad that I usually keep the car in reverse when the engine is shut down, that way it isn't a problem. Is this a tranny or clutch issue? What should I do about this?
If I need a new tranny then I would try something more beefed up to be able to handle a future 350/383/400.
Chuck
Chuck
Typically the clutch not fully disengaging
ye man its most likely gonna be the clutch im having the same problem with mine it's not that bad as your form the sound of it....Some of they guys here taught me a lil trick..i trow it into 5th gear while the car is on then into reverse works omst of the times...hoepfully it helps your situation.
This is common for non synchronized reverse. There could possibly be a problem with the clutch but even if the clutch is working properly it will still do it if you go to reverse too fast.
A good way to test proper clutch function is let the car idle in neutral and when you put the clutch in and hold it there for at least 5 seconds. After 5 seconds try to go to reverse. After 5 seconds if everything is working properly the gears should be stopped in the trans and it should not grind. If it still grinds after 5 seconds then it is possible the clutch is not fully releasing.
calgutie is right in that as long as the clutch is working properly the trick is to hit any of the forward gears first and then reverse. Hitting the forward gear will stop the gears from spinning and allow you to get reverse without grinding.
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,485 Times in 1,897 Posts
And once you've learned how to drive it correctly, change the fluid IMMEDIATELY, so that all the metal chips that have been shedding into the fluid off of the gears as they've been getting DESTROYED, are flushed out of it as much as possible and do as little further damage to the rest of the transmission as possible.
Chuck84TA
close
Thanks for the heads up guys! I will also change out the Tranny fluid also!
Chuck
Chuck
jmd
close
- Join DateJul 2000
- LocationAridzona
- iTrader Feedback Score(4)
- Car`86 SS / `87 SS
- EngineL69 w/ TPI on top / 305 4bbl
- Transmission`95 T56 \ `88 200-4R
- Liked:94 Times in 91 Posts
Originally Posted by LilSki
This is common for non synchronized reverse. There could possibly be a problem with the clutch but even if the clutch is working properly it will still do it if you go to reverse too fast. A good way to test proper clutch function is let the car idle in neutral and when you put the clutch in and hold it there for at least 5 seconds. After 5 seconds try to go to reverse. After 5 seconds if everything is working properly the gears should be stopped in the trans and it should not grind. If it still grinds after 5 seconds then it is possible the clutch is not fully releasing.
Quote:
<snip>
But if going into another gear, then first prevents it from happening, you still don't have a "must rebuild" situation
https://www.thirdgen.org/forums/post...33-post19.htmlOriginally Posted by jmd
Reverse is not synchronized so that's normal. <snip>
