clutch problems
clutch problems
i have a 89 irocz with a 350 tpi its been swaped with a t5 and i was trying to get a clutch kit that fit it i was having problems i wonder if anyone can tell me why i would be having problem fining a clutch kit
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: clutch problems
you should have no problems. You need a kit for a 305 f-body, 1pc rear main, 10.5" disc with a 153 tooth flywheel.
if you are searching for a clutch kit for a 350 powered f-body, you wont find one specifically listed for that application because it did no exist from the factory
Car: `86 SS / `87 SS
Re: clutch problems
There are two options
86 to 92 305 V8 5 speed f-body application.
Or if you ended up with an older engine with 2 piece rear main seal that happens to have TPI on it,
then 84 to 85 305 V8 5 speed application.
The clutches aren't different. The flywheel is.
Either way, you should post pictures of what you're "having problems" with. And part numbers of what parts you're "having problems" finding.
Communication is key.
theshackle
Aug 31, 2015 10:47 AM
db057
Aug 11, 2015 10:11 PM
rsrmoore
Aug 7, 2015 08:44 PM
