Thought Auburn's couldn't be rebuilt??
Old Dec 20, 2012 | 05:51 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Axle/Gears: 3.23 10 bolt limited slip
http://www.ebay.com/itm/Auburn-10-bo...d2f82c&vxp=mtr
The item you are buying is a 10 bolt 7 1/2- 7 5/8 GM Auburn posi unit. It is a used take out that has been disassembled cleaned , checked for wear and reassembled. It is a 3 series unit 3.23 and up ratios and it accepts 28 spline axles. Auburn part number is 109-542040.
Any questions please call 973-800-9007
Old Dec 20, 2012 | 05:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Thought Auburn's couldn't be rebuilt??
Says nothing about being rebuilt. Just cleaned and looked at.
Old Dec 20, 2012 | 05:59 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
So you think "disasembled" Is refering to the rear end housing and not the actual carrier which is for sale?
Old Dec 20, 2012 | 07:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
No, it sounds like the carrier was taken appart, looked over then put back together. Nothing mentioned about it being 'rebuilt' or even if its any good honestly.
Old Dec 20, 2012 | 07:24 PM
big gear head's Avatar
You can disassemlbe and reassemlbe the Auburn, but you can't rebuild it with new parts. When they wear out they are shot and only good for scrap metal. Auburn seems to have a way to rebuild them. I'm assuming that they have over size cones and they are boring the cases, but I wouldn't have one. I wouldn't use a brand new Auburn if it was free and I was getting sponsor money for using it.
Old Dec 20, 2012 | 08:21 PM
drupright99's Avatar
i'm debateing right now if i should use the new auburn i have or redo the one thats in my 83 t/a 500 pace. what is your reason for not useing the auburn. thanks, dan r------- e is drupright99@verizon.net. again, thanks
Old Dec 20, 2012 | 09:36 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Okay that adds a little more thought to my question. So they can be taken apart and reassembled but cannot be rebuilt? When they wear from normal usage does is actually "dig" into the metal casing? I hear all the time that they cannot be rebuilt, I guess I am just wondering why if one man made them why another man can't fix it ?
Old Dec 20, 2012 | 09:45 PM
Yes, the cones eat into the case, which fills the rear end with powdered metal, which runs through all of the bearings and gears and ends up as sludge in the bottom of the housing and axle tubes. Auburn must have found a way to recondition them because I have seen a remanufactured Auburn unit from Auburn, or at least that was the claim.
Old Dec 20, 2012 | 09:59 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Okay. So right now I have my eye out for a used 28 spline rear and most likely it's going to come with a used carrier. It has to be from a 3rd gen to keep with my original appearance. I would settle for an auburn to run for a little bit while I saved some more coin for an eaton. How can I tell just by looking if its bad or good?
Tonight I looked at this but unfortunatly it had a gov-loc and I passed. It was still a pretty good deal though. Kinda wondering if I should call guy back and let it sit in my garage till I got a better carrier.
$200
Complete rear axle taken from 1992 camaro rs. Axle has 87,xxx miles on it. Gears were replaced at 75000 miles. Gm 3:73 gears with auburn posi. Also has high performance diff cover. Axle has drum brakes. E-brake cables and rear sway bar not included. . All emails (except obvious spam) will be returned. Cash only. I will not ship the axle but I could possibly deliver it if local
Old Dec 20, 2012 | 10:05 PM
Not much of a way to tell by looking at it if it's all right or not. You could check the amount of backlash in the pinion gears, but if you don't have something to compare it to then that won't do you much good either. The more wear it has the more backlash will be in the pinion gears. As it wears the axle end play will also increase, so if it has a lot of axle end play then it has a lot of wear.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Sep 4, 2015 07:57 AM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
