How to tell if my trans has a shift kit
Old Jan 18, 2013 | 11:16 AM
muggymatt88's Avatar
Car: 89 Camaro Iroc
I have 700R4 is there a way to tell if its has a shift kit how? It shifts firm but that might just because the tv cable is tight
Old Jan 18, 2013 | 12:24 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: How to tell if my trans has a shift kit
You can check line pressure. Remove the 1/8 npt plug on the driver's side of the case. Compare your readings with oem readings. How is your full throttle 2-3 shift? That is a difficult shift to make firm without modification.
Old Jan 18, 2013 | 05:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You can also try holding it in a lower gear and see if it shifts up ,the better shift kits allow gear holding ( til the engine blows up )
Stock it will shift up at a certain point regardless of where the shifter is and then drop back when the throttle is released
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
