Rear differential leaking
Old Jan 22, 2013 | 06:41 PM
Alex Waller's Avatar
Car: 1984 Trans Am
Transmission: 700r4 automatic
hey guys i went and got my car inspected and my rear diff is leaking fluids and im wondering what might be causing that and the easiest way to fix it thank you
Old Jan 22, 2013 | 06:47 PM
kitt23's Avatar
Re: Rear differential leaking
Bad gasket
Old Jan 22, 2013 | 06:48 PM
Car: 1984 Trans Am
Whats involved with changing that out
Old Jan 22, 2013 | 07:26 PM
kitt23's Avatar
Old Jan 22, 2013 | 07:53 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Where is it leaking? Pinion seal? pinion nut/splines? Fill plug? Rear cover gasket? Left or right axle seal ?
Old Jan 22, 2013 | 07:59 PM
Car: 1984 Trans Am
I dont know all they said it was leaking and i need to fix all i know is that its cover in oil and grease
Old Jan 23, 2013 | 06:53 AM
big gear head's Avatar
First you must find where it is leaking. The procedure for fixing a leak depends on where the leak is. Go find the leak and then come back for an answer.
Old Jan 23, 2013 | 03:35 PM
Car: 1984 Trans Am
like i said covered lol
Old Jan 23, 2013 | 03:54 PM
Guest
Guest
Posts: n/a
Thats the pinion seal leaking...rebuild time!!!
-trust me...mine blew...(related causes...)
Old Jan 23, 2013 | 03:57 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Looks like the pinion oil seal.. Common
Old Jan 23, 2013 | 04:00 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Old Jan 23, 2013 | 04:01 PM
Rickey_85TA's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305 (5.0L) TPI
Axle/Gears: 9 Bolt Borg Warner Posi-traction
I would clean the outside of the differential with some degreaser and check it in a couple of days to see where the leak is comming from.
ALSO!! Don't drive that car if it's low on differential oil! You would be wise to go ahead and top off the oil level so your differential doesn't lock up on you when going down the road.
You will total out your car in a ditch or worse.
Old Jan 23, 2013 | 04:05 PM
Car: 1984 Trans Am
ok so the pinion seal and where do you put the oil in on it
Old Jan 23, 2013 | 04:50 PM
There should be a rubber fill plug on the differential cover. If not, then there is a fill plug bolt on the housing.
Add oil until it reaches the bottom of the fill hole and starts to run out.
A complete drain and fill is 3.5 pints of GL-5 gear lube (GM oil), SAE 80W or SAE 80W-90.
If you have a limited slip you will need the additive for that.
I did read somewhere on here that if you use synthetic gear oil you don't need the additive.
Old Jan 23, 2013 | 05:01 PM
Car: 1984 Trans Am
well guess when it warms up here i need to check it out cuz its freezing here
Old Jan 23, 2013 | 05:07 PM
Looks like the pinion seal to me. Sometimes it's just a bad seal and sometimes it's a bad bearing. Other times it could just be the nut is backed off. When you get the chance to work on it come back and you can go over all of the options.
Old Jan 23, 2013 | 05:13 PM
Car: 1984 Trans Am
yea wont be till march when the major work. when it gets semi warm ill check it out
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
E Rod
Aug 28, 2015 05:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
