1992 Camaro RS differential
Old Jan 24, 2013 | 02:42 PM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
I was wondering if anyone knows what differential I have in my car. I know th egears are 2.73 but is it positraction, limited slip or open? LO3 with the 700r4. Thanks
Old Jan 24, 2013 | 02:50 PM
big gear head's Avatar
Re: 1992 Camaro RS differential
Positraction and limited slip are the same thing. If it's the original rear end then check the RPO codes on the sticker on the bottom of the console lid or behind the spare tire cover and see if you have the G80 code. If you don' then it's a standard differential.
Old Jan 24, 2013 | 03:22 PM
Jake_92RS's Avatar
The sticker in the glove compartment in the back of the car?
Old Jan 24, 2013 | 04:32 PM
There are 2 places that I know of that GM put the sticker. It should be either on the bottom of the console lid or on the back of the spare tire cover in the back of the car.
Old Jan 24, 2013 | 05:06 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
You could also look for a metal tag on the differential case and/or jack up the rear and turn one of the wheels. If the other wheel turns in the opposite direction it's open if it turns in the same direction it's limited slip. If it's working correctly.
Old Jan 30, 2013 | 07:52 AM
Pat Hall's Avatar
Being that you have a run-of-the-mill 305 TBI car, it's about a 99% guarantee it's a peg-leg rear. While it's not impossible for a TBI car to get a posi rear, it's highly, highly unlikely. My 89 LO3 car had a peg-leg 2.73 from the factory until I cured that problem with a 3.23 posi/disc rear!
Old Jan 30, 2013 | 06:31 PM
Codes are worthless. With cars this old, who knows what's been changed over their lifetime. As an example, I have a 91 rear with an Eaton posi and Superior axles in my car, but with the OE weenie highway gears. 3.73. Ya think a bunch of "codes" would tell you about all that?
Ummmm.... I forgot to update my "codes" when I did all that work. Sorry.
Changed the fluid lately?
I thought not.
While you're catching up on the overdue maintenance, LOOK AT THE PARTS. Whatever you see, that's what you've got.
This method (looking at the parts) is ABSOLUTELY 100% IRONCLAD GUARANTEED FOOLPROOF DEAD-ON-***** ACCURATE. No possibility for error exists.
Old Feb 1, 2013 | 01:20 AM
Pat Hall's Avatar
Although Sofa put it real bluntly as he always does, he's 100% correct! Taking off the cover and actually looking in there is the only foolproof way to determine what you have in there.
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
