Paying for 9 bolt swap
Old Feb 15, 2013 | 09:13 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Can you guys help me ballpark what it would cost for me to have a shop install a takeout 9 bolt posi with 3.27 gears in my 2 series 9 bolt?
What parts should I buy ahead of time? I already have a good condition used 9 bolt posi with gears.
Old Feb 16, 2013 | 09:00 AM
big gear head's Avatar
Re: Paying for 9 bolt swap
Get a good installation kit from Randy's Ring & Pinion. That should be all you need. Probably looking at around $300 to $500 for the installation.
Old Feb 16, 2013 | 11:23 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Or you could try it yourself and save some money. I just did exactly what you want for the first time. All the info is on the board. Probably take a lot longer but it was interesting to do. Have you checked how much life is left in the carrier you want to put in? If it's all original you may want to re-shim it and/or may need some machining done.
1984HO
Mar 19, 2021 11:59 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
gta90
Sep 15, 2015 04:00 PM
Amillionoh7
Aug 7, 2015 01:24 PM
