TCC solenoid problems
Old Feb 16, 2013 | 12:51 PM
RaptorATF's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Driving home on my way home from school, my tcc failed to disengage and tried to stall going up a steep hill. I had to have the pedal to the floor to keep the car alive. Later on, I took my car for a test drive to confirm the problem and my camaro ran like normal so I assume it was just stuck.
My question is, if it was just the solenoid that was stuck, is there a high chance of that happening again, or was it just something that happens every so often? I hear its a common occurrence in GMs.
Thanks!
Old Feb 16, 2013 | 01:00 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: TCC solenoid problems
I'd say it's likely to happen again. Probably a bad solenoid.
Old Feb 16, 2013 | 03:03 PM
RaptorATF's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Hmm ok. How much would that usually cost to have done at a shop? Or is it something that's simple enough to do myself? (considering I'm a cheap college student :P)
Old Feb 16, 2013 | 03:14 PM
It's easy. You drop the pan and 2 bolts hold the solenoid.
Old Feb 16, 2013 | 03:17 PM
RaptorATF's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
That's it? Cool. Thanks for your help.
Old Feb 17, 2013 | 05:15 PM
RaptorATF's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Actually I've got another question. If I just temporarily unplug the solenoid, I should be fine for a 30 min stop and go route, would you think? And when I have time to change the unit, is there anything I can do to prevent the trans from slipping when using fresh fluid? It ran like new but I have no knowledge of when it was last changed.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
