is this setup worth $450?
Old Mar 17, 2013 | 06:08 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I'm talking to a guy on craigslist who is selling a 94 Camaro rear end that originally had 3.08 posi gears in it. Well he also has a new Detroit locker and a new girdle for it, thing is that he said the guy who had it before him installed a set of 3.73 motive posi gears. He's wanting $450 for everything or $150 for the axle its self, is this worth it?
Old Mar 17, 2013 | 08:06 PM
big gear head's Avatar
Re: is this setup worth $450?
A Detroit Locker, if it actually us a Detroit Locker, is over $500, maybe $600. Be sure that it is a Detroit Lokcer before giving him any money. If the gears were set up correctly then the rear end is worth the money. If the gears were not set up correctly then plan on installing a new set of gears. If you mean a T/A Performance cover when you say girdle then they are about $170.
Old Mar 19, 2013 | 11:29 PM
Engine: L31 350
Well im getting the rear, dont forsee me having the extra for the locker and girdle. But this is a street car so they arent really needed for street use. Think the rear end will though. Im paying $150 for it when I get paid. Just going to verify its a posi before I pay a dime. A fourth gen drum rear will bolt in and fit correctly right? No brake line altering? Its a 94 posi diff with 3.08 gears but it has had 3.73 motive gears installed
Old Mar 20, 2013 | 12:30 AM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
Originally Posted by evilemokid94
... A fourth gen drum rear will bolt in and fit correctly right?
why not just put in a disc brake rear while you're going through the trouble of changing diffs?
Old Mar 20, 2013 | 07:12 AM
The '94 is going to have the Auburn differential in it. This is not a very good differential. They wear out and they are not rebuildable. Just scrap metal at that point. If this has been run hard then it probably is worn out. Maybe the rest of the rear end is worth the $150, but I wouldn't give $5 for a used Auburn.
Old Mar 20, 2013 | 10:31 PM
Engine: L31 350
Well didnt getin it, i was an open differential or a very worn differrntial. Only one tire spun. Can I have posi 3.73 gears installed in my 3.42 gov lock rear?
Old Mar 21, 2013 | 08:53 AM
Yes.
Bubbajones_ya
Jul 6, 2024 08:32 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
Stryker412
Sep 7, 2015 09:11 AM
