Shifter moves up and down when clutch is dumped..?
Old Mar 17, 2013 | 07:12 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Alright so when ever I do a hard launch or I dump the clutch my shifter moves up and down..IDK if thats normal or whats going on...My friend has an LT1 and his does do the same except his has more movement than mine...Anyone know what this is?thanks!
Old Mar 17, 2013 | 07:46 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Shifter moves up and down when clutch is dumped..?
Check for a broken transmission and motor mount.......................
Old Mar 17, 2013 | 07:57 PM
BOTTLEDZ28's Avatar
Transmission: A4
Like mentioned above, check to see if the rubber transmission mount has ripped in two. The mount bolts to the transmission and the crossmember and keeps the transmission secured in place. The rubber dry rots over time and gets abused from hard launches and the end result is a total failure of the mount.
if it is bad then replace it with a poly mount from Energy Suspension.
Old Mar 17, 2013 | 08:31 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The poly mount may induce unwanted vibration.
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
Old Mar 17, 2013 | 08:57 PM
calgutie's Avatar
Car: 1984 Z28
Great thanks for the help you guys ima look into it...on summit if I wanna buy a new mount...anyone got a link to what it looks like and the price on it?
Old Mar 17, 2013 | 09:22 PM
BOTTLEDZ28's Avatar
Transmission: A4
http://www.summitracing.com/parts/en...t/model/camaro
Its your call on the material you want to use. Either rubber (stock) or Polyurethane (aftermarket). I have always used poly material for the trans mount because it can take alot more abuse then a stock replacement. Some guys dont drive their cars hard and therefore a stock rubber replacement mount will be fine. Others tend to get on their cars from time to time and thats where I suggest a poly mount.
James mentioned that you can get slight vibration from a poly mount. That may be true in some cases but I cant argue or favor his statement since way to many variables come into play with drivetrain vibration.
Old Mar 17, 2013 | 09:25 PM
calgutie's Avatar
Car: 1984 Z28
Perfect well my car is my daily driver and I sometimes do tend to pop the clutch for the occasional burn out or street race...but I might just go with this instead...Where exactly does that piece go and will it for sure fit my car?
Old Mar 17, 2013 | 09:48 PM
BOTTLEDZ28's Avatar
Transmission: A4
That mount goes in between the transmission and the crossmember that holds the transmission in place under the car. You will see the mount when you get under the car and look around the bottom of the transmission. You cant miss it. Get a small jack and slowly jack the transmission up an inch or so after you have loosened the bolts holding the mount in place and it will come out. Installation is the reverse of removal.
Old Mar 17, 2013 | 09:49 PM
calgutie's Avatar
Car: 1984 Z28
lright well ima be replacing the clutch so now is a good time to replace it.
Old Mar 18, 2013 | 06:40 AM
JamesC's Avatar
The newer redesigned mount, as described in the link I provide above, is 3-1142. Though apparently shorter, it's approx. the same height as the Prothane version, which caused less vibration in my car than the 3-1108 but vibration nonetheless.
I purchased an angle finder recently, so at some point I'd like to measure pinion angle with both the Prothane and OE rubber mount in place.
A search is always a prudent idea on TGO:
https://www.thirdgen.org/trannymount
Best of luck with your project,
JamesC
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Fronzizzle
Sep 8, 2015 12:10 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
