9bolt setup pattern
Old Mar 24, 2013 | 06:02 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
9bolt setup pattern
How does this pattern look?
Attached Thumbnails 9bolt setup pattern-2013-03-24_18-09   9bolt setup pattern-2013-03-24_18-09
Old Mar 24, 2013 | 06:24 PM
Twin_Turbo's Avatar
Re: 9bolt setup pattern
very hard to see, get the yellow paste
Old Mar 24, 2013 | 07:47 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
That was anti-sieze, guess it doesn't photograph well.
Are these any better?
I can do the yellow tomorrow.
Attached Thumbnails 9bolt setup pattern-2013-03-24_17-23   9bolt setup pattern-2013-03-24_18-06   9bolt setup pattern-2013-03-24_18-06
Old Mar 24, 2013 | 08:31 PM
big gear head's Avatar
Pinion is too deep. Take about .003 out of the pinion shim. Try to get some real gear marking compound.
This is a new gear, right?
Old Mar 25, 2013 | 09:53 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
It is a new Motive set I bought from a board member.
I took about .004 off the pinion shims. Does it still look deep to you?
Attached Thumbnails 9bolt setup pattern-2013-03-25_22-38   9bolt setup pattern-2013-03-25_22-38   9bolt setup pattern-2013-03-25_22-37
Old Mar 25, 2013 | 10:13 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
And the coast side
Attached Thumbnails 9bolt setup pattern-2013-03-25_22-40   9bolt setup pattern-2013-03-25_22-40   9bolt setup pattern-2013-03-25_22-41
Old Mar 26, 2013 | 07:07 AM
Just a little. Maybe about .002 more and it should be right where it needs to be.
Old Mar 26, 2013 | 08:15 AM
Twin_Turbo's Avatar
I would leave it like this, it will migrate outwards as you put power on it., You ARE pulling a pattern whilst turning the pinion and dragging the ring gear right?
Old Mar 26, 2013 | 11:04 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Yes Twin turbo, I put as much load on it as I could. I used 2 pry bars on the posi as a friend rotated the ring gear by the bolts.
Old Mar 26, 2013 | 11:19 AM
I use an axle to turn everything against the pinion bearing preload. It's much easier to turn and gives a more clear pattern. If the pinion bearing preload is set correctly it will give plenty of resistance to make a nice pattern on the ring gear.
Old Mar 26, 2013 | 06:10 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Well, If Big Gear Head and Twin turbo can't agree I just don't know what I'll do! (Kidding )
What would the theoretical difference be between dropping the pinion .002 and leaving it where it is now?
I know pattern reading can be a little subjective, and given the fact that these guys are working off of pictures, I'd have to say it's pretty darn close. Of course having two board members that I hold in such high regard disagree over such a small discrepancy leaves that inkling of doubt that can drive a man to drink!
Seriously though, I can't thank you two enough for all the help you have given me on this build. I have learned a ton about something that used to really intimidate me. If either of you is ever in Carlisle I owe you a dinner!
Old Mar 26, 2013 | 08:41 PM
What I see is a sharp line at the root of the drive side and a slight taper toward the root at the end of the pattern. It shows much more in the first picture in post 5, but the second picture looks pretty good. It's hard to make a decision when you have patterns that don't agree.If you want to leave it like it is it probably won't hurt anythng at all. I like to go too far in one direction and then too far in the other direction to see just what the pattern looks like, but if you have got tired of changing shims then call it good enough.
Old Mar 26, 2013 | 11:00 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
I think what happened there is I marked four sets of three teeth, when I turned the gears to take pictures one or two of the sets may have run across the pinion without preload and messed the pattern up.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Pac J
May 17, 2020 10:44 AM
tmellott89
Oct 14, 2015 02:06 PM
tattmann
Sep 27, 2015 05:20 PM
dimented24x7
Sep 17, 2015 06:58 AM
