1986 TPI TV Cable
Old Apr 14, 2013 | 07:11 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
1986 TPI TV Cable
Does anyone know the part number for a TV cable for an 86 TPI set up? I did a search and found 25521263 for 87-88 and 10163879 89-92 but no listing for 85-86?
Long story short, I ordered a TV cable for my 86 TA from Napa and now that its installed I find the cable won't adjust? It's as if the inner cable was way too long. Even at its minimum adjustment still doesn't really pull the cable tight and does not ratchet the adjuster. Does anyone know what would cause that?
Old Apr 15, 2013 | 12:13 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 1986 TPI TV Cable
85 & 86 throttle body bellcrank is same as 87-89.
What PN did you get from Napa?
Old Apr 15, 2013 | 06:45 PM
I believe it was NAPA part number ATP 17901? The cable length seems perfect. Straight line from the transmission to the throttle bracket and it fits like a glove. The inner cable on the other hand, is like at least 1" too long. Even at WOT the bellcrank is just starting to pull the TV cable and thats with the adjuster backed down as short as it will go.
Old Apr 15, 2013 | 07:00 PM
Get a 87-88 bracket.
Old Apr 15, 2013 | 07:11 PM
elpulpo's Avatar
acording to the parts manual the part number 25521263 is correct.
Old Apr 15, 2013 | 07:40 PM
I'm pretty sure all the throttle brackets were the same. Can anyone else confirm one way or the other?
Old Apr 15, 2013 | 07:41 PM
Thanks for confirmation.
Old Apr 15, 2013 | 08:46 PM
elpulpo's Avatar
not all the brackets are the same part numbers are different
Old Apr 15, 2013 | 09:17 PM
So does anyone know what the difference is? I took a look around and they all look the same?
Old Apr 17, 2013 | 09:24 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
I recently did this to my 86 iroc TPI car and the GM part # for 86 is......25521263
Old Apr 18, 2013 | 06:06 PM
Thanks for confirming. That's what I'll order and hopefully that will be the end of it.
Old Apr 26, 2013 | 05:35 PM
Just in case anyone was curious, I ordered the new cable (AC Delco 25521263 ) and that was exactly what I needed.
Old Apr 28, 2013 | 09:07 AM
Pat Hall's Avatar
Good deal. Yeah most of the aftermarket TV cables are pure junk. The only one I've seen that matches up pretty close to the original ones is the ones made by Pioneer. What surprises me is I didn't even think you could still order an original one. That's good to know!
Caspar
Jun 19, 2016 11:19 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
