Shifter Cable
Old Apr 25, 2013 | 06:12 PM
transamman83's Avatar
Car: 83 Trans am, and 91 Camaro
Engine: both have a 305.. For now
Shifter Cable
So i got a used oem shifter cable and went to install it today. For some reason I can't get the tranny to go into park now. Is there some adjustment anywhere. It will shift fine through all other gears but won quite go into park. Any Ideas?
Old Apr 25, 2013 | 06:21 PM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
Re: Shifter Cable
that happend to me also! go under the car and put the linkage into park and reinstall your cable.
Old Apr 25, 2013 | 08:38 PM
Re: Shifter Cable
That is how I installed it. I will mess around with some adjustments and see if I can get to go. Thanks for the tip though.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
