Lacking Rear Swaybar?
Old Apr 27, 2013 | 11:46 AM
rwerk91's Avatar
Car: 91 Camaro
Engine: LS1, LSXRT &102mm TB, Cam,225 Heads
Axle/Gears: 9" 4.10 w/31 spline axles
So Im buying back a car I sold to a friend a couple years back 92 Z-28. Primarily because it has a descent 9" setup in it. Looking at the photos and realized it has no rear sway bar. its not a big deal as I will just swap the one out on my car now if need be. My question is to someone who has a greater knowledge in suspension than myself, is there a reason for the lack of the sway bar? this car has been driving around at what seems perfectly fine for at least 7 years now so why could/would this be. What would be the motive to remove this? Thanks guys
Old Apr 27, 2013 | 12:08 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Lacking Rear Swaybar?
Maybe the attachment to the axle tubes wasn't possible without extra work and they forgot about it. Or....
But anyway I'm pretty sure they had no problems with snap-oversteer.
Old Apr 27, 2013 | 06:18 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Check out #4 on this thread. He explains it.
https://www.thirdgen.org/forums/susp...iscussion.html
Old Apr 27, 2013 | 06:41 PM
rwerk91's Avatar
Car: 91 Camaro
[quote=antares57;5548159]Check out #4 on this thread. He explains it.
https://www.thirdgen.org/forums/susp...iscussion.html[/quote
Thanks. Helps explain it a little. That's actually exactly how this one is set up with the panhard as well as LCAs. Suppose when it gets here Ill have to take it out and see if I prefer it to the setup in my 91 before I swap it all out.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
mdtoren
Aug 23, 2015 12:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
