97 T56 in a 1992 speedO not working
Car: 92rs
Engine: 400 sbc
Transmission: Fti 400....T56
Axle/Gears: ford 9in
I have a 1992 RS. Which I have bulit a 385 all roller and put a 1997 T56 behind it. Right now I can not the the speedometer to work.. I got the right VSS hookup... The arm starts at 0 the then will jump around then max out any help would be great thanks to you all
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 97 T56 in a 1992 speedO not working
Did you install a Dakota digital sgi-5 ?
Car: 92rs
Engine: 400 sbc
Car: 92rs
Engine: 400 sbc
Engine: Lb9
Transmission: M20
You got it right, if you had tbi you don't need to use the vss buffer .
Car: 92rs
Engine: 400 sbc
Car: 92rs
Engine: 400 sbc
Ok so I got it in wired it up but only one green light is on it says the top on means no signal did I wore it up wrong
Power gn
Purple from vss to ground and other other one to ground as well yellow from vss to Sig and to other out put 3
O
Power gn
O
Car: 92rs
Engine: 400 sbc
also the gauge it self starts a 0 the gose up till it pegs out as I start to drive
Engine: Lb9
Transmission: M20
output 4 is the 4k optical to your speedometer.
Car: 92rs
Engine: 400 sbc
i got it to work thanks man for the help... I had to have the 3an4 switch on then walk in down to the right speed .. but it is dead on now thanks
BlackphantomZ28
Aug 31, 2015 10:29 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
beachrodder
Aug 7, 2015 04:27 PM
