T 5 replace help!
Old May 7, 2013 | 08:45 PM
yayoWHITESACK's Avatar
Car: 1987 z28 all stock + tricked 85 z28
Engine: 388 stroker + Procharger D1SC
Transmission: TKO 600
Axle/Gears: richmond 3:73, EATON, moser shafts
T 5 replace help!
what should i get and where should i get it
i wanted a Richmond from jegs but the wait list is into next year
im building hopfully close to 600 lb ft / bhp
Old May 8, 2013 | 08:17 AM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Axle/Gears: Strange S60
Re: T 5 replace help!
There is quite a bit of info on this site about replacement transmissions. There are a couple of performance T5's. One by a company called G force I believe. The main thing about the T5 is its weak case though. A lot of people go with a Tremec TKO 500 or 600. (I have the TKO 600). They are rated for 500 ft-lbs and 600 ft-lbs respectively. They also require a conversion kit. Mine is from Forte's Part Connection. Another option is a built T56 that other aftermarket companies build.
BTW if you get any traction at all your rear end is going to explode just like mine just did.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
