Problems with a 700r4
Old Jun 20, 2013 | 05:06 PM
JJR82's Avatar
OK i have searched and cant find anything that has to do with the problem i am having. The car is a 1990 Camaro RS with the 5.slow. This moriing i was leaving a stop sign under a easy to moderate accel. and the car went from 1st to 2nd fine and then shifted into third but about 5-8 sec after it shifted into third i lost everything. I pulled it over and tried every gear even reverse and nothing. the drive shaft is still there and the fluid was fine a couple days ago.(i check it once/twice a week due to a minor leak) I am going to tow it home in a lil bit. i replaced the trans in march, came out of a astro van with a 4.3. dont know the mileage.
Old Jun 22, 2013 | 03:07 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Problems with a 700r4
If you have nothing at all may have damaged the pump gear that generates the hydraulic pressure to make it work
or the torque convertor that connects the engine to the trans.
T700 Problems and causes list
http://blazerforum.com/forum/engine-...10/#post393836
Old Jun 28, 2013 | 12:53 AM
JJR82's Avatar
thank you, i had failed to replace the torque converter when i swaped out the transmissions. as fas as everyone has told me its the tq. but ill check the pump issue also.
Old Jun 28, 2013 | 02:24 PM
JJR82's Avatar
the fluid onlt drops maybe a half inch when started.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
