T56 ?s
Old Jun 21, 2013 | 05:39 AM
fatalicshock's Avatar
Car: 87 Trans Am
T56 ?s
So i first of i dont know if this goes here or where ever but i just did a t56 swap in my 87 ta and i cant put it in reverse because of my center console is in the way so what should i do. Mod the 3rd gen one or get a 4th gen(even know i think they are hideous) thanks
Old Jun 21, 2013 | 03:56 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: T56 ?s
I unbolted the shifter stick and put it on the other side. Problem solved.
Old Jun 26, 2013 | 07:56 AM
Car: 87 Trans Am
Re: T56 ?s
it is on the opposite side
Old Jun 26, 2013 | 08:03 AM
Car: 87 Trans Am
Re: T56 ?s
Here is a pic
Old Jun 26, 2013 | 09:05 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: T56 ?s
Huh, that is weird. With the stock shifter, I was able to put the shifter stick on the other side without any issues, along with many others on the forum. Is your console installed correctly? Could be sitting back a bit and not in the forward grove part of the radio pod.
Old Jun 26, 2013 | 09:09 AM
Car: 87 Trans Am
Re: T56 ?s
yea i didnt bolt it in so it could move when i put it in reverse but when it was in right it still hit
Old Jun 28, 2013 | 03:35 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: T56 ?s
thats pretty wierd . what trans mount and x member are you using ? only thing i can think off is engine trans isnt centered, shifter is bent , or crenter console is offdef a head scratcher
some thing is off i think its the trans idk i didnt have this issue also
Old Jun 29, 2013 | 09:02 AM
Car: 87 Trans Am
Re: T56 ?s
I bought my crossmember from spohn other that that everything else is eather stock or out of the 97 ta i got it out of
Old Jul 11, 2013 | 07:58 AM
Car: 87 Trans Am
Re: T56 ?s
Also another question is i have digital dash in my car so i have an eletric speedo in my car and my speedo connecter dosnt fit in any on the trans so would i be able to splice in a 4th connecter into my speedo wire or would i have to buy a box
Old Jul 11, 2013 | 07:40 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: T56 ?s
You need the Dakota Digital SGI-5 box as the PPM is different between the T56 and 3rd electronic speedos. So you need the box to do the conversions for you.
Old Mar 30, 2014 | 07:36 PM
Car: 87 Trans Am
Re: T56 ?s
so i figured out (finally i know) that trans wasn't centered i did pay as close of attention as i should but it is center now and still rubs a little bit
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
