Trans Conv-switch
Old Jun 22, 2013 | 08:54 PM
nickyakker's Avatar
Car: 1982 Firebird T/A
Trans Conv-switch
So I'm deleting vacuum lines and on my chart it shows a line going from my canister to "Trans Conv- switch" . I looked for the switch and there is a wiring harness with a vacuum diaphragm of sorts. Nothing really looked connected to it other than the canister. Do I need to worry about this thing? I have a 200r4
Old Jun 22, 2013 | 09:04 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Trans Conv-switch
IIRC a vac switch was part of the convertor lockup wiring on early cars
Old Jun 22, 2013 | 09:22 PM
nickyakker's Avatar
Nothing is currently hooked up to the transmission.
Should I try to get it operational? If so how to I do it without hooking it up to the canister?
Old Jun 26, 2013 | 07:22 PM
nickyakker's Avatar
So I hate to harp on this issue but I don't know too much about transmissions. So I have a couple questions.
1.What is the purpose of Transmission Lock Up
2. Can it be bypassed?
3. If not how much vaccum does it need or why is there a switch coming from my vaccum system?
If I can get any clearification on these issues that would be great. Thanks
Old Jun 26, 2013 | 07:36 PM
ZF6camaroZZ4's Avatar
Car: 86 Z/28 IROC-Z
Axle/Gears: 9 Bolt 3.27
Lock up is for better fuel economy. Also it keeps the transmission from running on the stall speed of the converter in upper gears.
Since the Canada version wasn't control by the ecm, The vacuum switch unlocks the converter under full throttle type condition's. < Brake switch unlocks it too.
Theres lots of ways of wiring it up.
Old Jun 26, 2013 | 07:40 PM
nickyakker's Avatar
Awesome bud, thanks for the quick response. any chance I can get a wiring diagram for wiring it up?
Old Jun 26, 2013 | 08:43 PM
nickyakker's Avatar
With a little research im finding that when there is less vaccum, the switch turns lockup off. but with vaccum it turns it on (ie cruizin speeds). So im just going to skip the switch and run the lockup vaccum line to the one sticking out the back of the bottom of the carb down at the manifold.
Old Jun 27, 2013 | 09:37 AM
Car: 86 Z/28 IROC-Z
I only have stuff on the 700r4. Haven't noticed any info here on the 200, but the corvetteforum & turbobuicks has some info and pics. (do a google image search)
You sure the thing isn't lockup now? Maybe the PO already did something to it. Also, probably no big deal if you have like 3.73 gears..... 2.73's, you would need the lockup working for sure.
But, yeah... the switch needs to see manifold vacuum.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
