best t5 clutches?
Old Jul 10, 2013 | 07:31 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
best t5 clutches?
What are GOOD performance clutch options for a non wc t5? I've got a 87 z28 with bad 305 that's being replaced with a 357 and know stock clutch is pooped out.
Was looking at Zooms clutches from Autozone ranging from upgraded friction disc/pressure plate to kevlar street/strip with best pressure plate offered
Old Jul 10, 2013 | 07:43 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: best t5 clutches?
I've had a really good experience with centerforce's dual friction. My TPI is peaking 350 torque to the wheels and the clutch has never given an unexpected slip.
Old Jul 10, 2013 | 07:56 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
My biggest concern is clamping load for launching.....I know I know the t5 has a weak case and such lol
But lately been seeing more and more t5 equipped thirdgens at drag strip running HARD lol
Old Jul 10, 2013 | 08:27 PM
Well one thing I can assure you of: it's not because the T-5s are getting any stronger lol
I also have had good results from the CF DF. But for that matter, over my 40-odd years of driving stick shift cars, I've had Ram, Zoom, Hays, McLeod, B-W, and a couple of local rebuilders here and there (that I can remember... probably others besides). And I've got good service out of EVERY SINGLE ONE, IF it was installed right. Likewise, if it was installed wrong, didn't matter what brand it was, it screwed up.
Moral of the story: Pay more attention to creating a PERFECT installation and less to the name on the box.
Old Jul 10, 2013 | 08:35 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
I'm just asking what has worked for people in real world setups
I have a centerforce clutch in my Chevy 4x4 and is supposed to be best money can buy......and it slips......badly. But oh well
Old Jul 10, 2013 | 08:40 PM
Old Jul 10, 2013 | 08:55 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
I have a Zoom HP1675-1A on a w/c T-5 with a Fidanza aluminum flywheel. It does just fine for me.
Old Jul 10, 2013 | 09:29 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Well considering I prepped by having new flywheel checked for trueness. Then cleaned the crap out of it with brake clean, also pressure plate. Put everything together by hand then torqued everything to spec making sure not to pinch friction disc.
After all that drove close to 1200 miles being easy on it. First pull I made it slipped.......grr
Old Jul 10, 2013 | 10:08 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I've installed several clutches in front of T5's over the past 20 years, and the Centreforce dual friction is a gem. The faster it spins, the harder it clamps.
But the last clutch I installed last fall was just a plain old vanilla Luk stock replacement. I went this route because I'm getting older and I want the T5 to last. And I've learned that you can have fun by driving a car really hard without breaking it.
Old Jul 11, 2013 | 07:06 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Well I won't drag race it much but wanting to get into road racing one day like track days. That or doing auto x events. So want anything that will really shifting all day and not start slipping. Do the centerforce dual friction clutch still use the weights? The older one scared me away lol.....had that setup in my MK3 supra and had it come apart.....little weights broke the bellhousing
Old Jul 11, 2013 | 03:46 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Did you measure thicknesses? Sometimes it's necessary to shim the T/O bearing or the flywheel to ensure that you have proper engagement. Otherwise, they can slip. Likewise, did you ensure that there were no external contaminates on the surfaces? Anything from a RMS leak to dirty hands during installation can compromise the clutch.
That said, I've had a Centerforce D/F in my IROC for a hundred years, and it's been flawless. That trans along with the same clutch are moving into my GTA shortly.
Old Jul 11, 2013 | 04:05 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I like my spec stage 1
Old Jul 11, 2013 | 08:11 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Ram clutch behind my 10.5:1 comp 355 and no issues. In fact i just took it out because im having trans leaking issues and the clutch and flywheel look like i put them in yesterday.
Old Aug 13, 2013 | 08:14 PM
nitehawk's Avatar
Car: 83 transam
Axle/Gears: 4:11 posi
I,ve had a cf df in my chevy 4x4 for a decade now and it's never missed a beat. it's been full of mud, water, everything. I wouldn't hesitate to get another one.
Old Aug 24, 2013 | 02:37 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
I have a Zoom HP1675-1a, and I detest it. I'll be looking at a Spec clutch if my T5 survives.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
