TH700 problem and repair
Old Jul 29, 2013 | 06:03 PM
hentsy's Avatar
Car: Chevy Van G20
Engine: 5.7
Transmission: TH700
Hello.
My problem started 2 months ago, when suddenly after 5min parking the gearbox was not shift over 2nd gear in "D". Starts with 2nds gear, few seconds moving and then shift to 1st gear. It shifts to 3rd from 1st, when speed up to max rpm. 4th gear wasn't absolutely. Same case is with "OD" too. In "3" its starts with 2nd and shifts to 3rd without problems. Also it wont downshift to 1st. Those shifts (2-3, 2-1 and 1-3) were decent - no slide or any other anomaly.
Last week i finally found time and uninstalled transmission. I was disassembled oil pan, valve body and 1-2 accumulator housing. Found that 1-2 accumulator spring(yellow) was into halves. Becouse of that, the piston was scratched the inner side of housing. Gasket was okay.
Is this possible, that it caused the problems?
There was no metal dust in oil pan and VB. Only little sedimented black **** in the bottom of pan. Other oil was red, not black and there wasn't any burn smell.
I also broke that big black gasket between valve body and separator plate, because it was so fragile. Have to buy new one from ebay, if possible.
I have read many manuals, but still i dont understand all. There was 3 check ***** in VB. Didn't understand, where exactly they're go. I found several different pictures for these. My gearbox number is 8YMM123C
Excuse me for my bad english.
Waiting for any kind of help,
Henri
Old Jul 29, 2013 | 10:08 PM
morgsie's Avatar
Re: TH700 problem and repair
I recommend putting in a shift kit. I used Probuilt's and like it very much: https://www.700r4l60e.com/store/product.php?productid=533&cat=65&page=1
Old Jul 30, 2013 | 02:11 PM
hentsy's Avatar
Car: Chevy Van G20
Engine: 5.7
Transmission: TH700
This isn't fit to my gearbox, i think. They say this is for 1982-1987 models, but i have 1988. (8YMM123C)
Old Jul 30, 2013 | 07:48 PM
morgsie's Avatar
https://www.700r4l60e.com/store/prod...&cat=65&page=1
Posted the wrong one, sorry. Very complete kit, comes with modified instructions, corvette servo (must have) and a brand new separator plate (w/ gaskets). If you provide enough information Dana (Probuilt) usually predrills the separator plate. He also recommends a better torque converter (https://www.700r4l60e.com/store/prod...&cat=59&page=1), but I understand if that is out of your budget.
Old Jul 31, 2013 | 09:54 AM
hentsy's Avatar
Car: Chevy Van G20
Engine: 5.7
Transmission: TH700
Okey, that's better
But what you think, will this kit removes my problem? Sure thing is that the 1-2 accumulator spring was broken. Is this possible that this spring causes that kind of problem?
Do I understand right, in this kit is also this 1-2 accumulator piston, gasket and housing? I need housing and piston too, because mine are a little bit scratched.
Anyway I sent them email to ask, will they ship it to Estonia and how much is cost.
Old Aug 2, 2013 | 03:27 PM
hentsy's Avatar
Car: Chevy Van G20
Engine: 5.7
Transmission: TH700
some pics
Old Aug 30, 2013 | 01:54 PM
hentsy's Avatar
Car: Chevy Van G20
Engine: 5.7
Transmission: TH700
I ordered and istalled this kit. Still the same problem. Any thoughts?
Old Aug 30, 2013 | 08:53 PM
bwiencek's Avatar
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
That's because you didn't fix the real shift problem if you only did the shift kit and replaced the accumulator spring (with the upgraded parts or eliminated it). The 2nd gear starts, random downshift to 1st then upshift to 2/3, etc. is either a problem with the governor not working properly, a mis-adjusted TV cable, stuck TV Valve, or a stuck valve in the valvebody.
Since (I'm going to assume here) you probably pulled and cleaned the valve body thoroughly when you installed the shift kit and made sure all of the valves operated smoothly and there were no burrs or binding in it, then I would start at the governor and make sure that the valve operates smoothly and the gears (drive and driven) are in good shape, etc.
Old Aug 30, 2013 | 09:29 PM
Pro Built Automatics's Avatar
Describe what is happening here exactly. Do you have 3rd gear? 4th gear? If you are having a hard time getting 3rd gear, and or it won't hold, then the black stuff in the bottom of the pan was most likely the 3-4 clutch material.
Old Sep 3, 2013 | 09:10 AM
hentsy's Avatar
Car: Chevy Van G20
Engine: 5.7
Transmission: TH700
On "D", it start with 2nd gear, then it shift to 1st and that's all. Driving with that 1st and shift manually to "3"(number 2 on the display. I have "2" and "1", because originally there was TH350(?) with 3 gears.), then it shift up, but I dont understand anymore, is it 2nd or 3rd. I think, it's 2nd, because @50km/h, the rpm is too high, listening with ear.
Today I disassembled the governor and it was like this:
oops
So anyway I need to get new governor gear. Have to do little research, is this available in Estonia. (if anyone have for sale and can send it to Estonia, let me know)
Can it cause the problem I have?
Old Sep 25, 2013 | 07:41 AM
hentsy's Avatar
Car: Chevy Van G20
Engine: 5.7
Transmission: TH700
Replaced the governor gear, still the same.
Old Nov 10, 2013 | 04:43 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Shift cable bad? Cable to trans bracket broken? Bad shifter adjustment? If your indicator is not reading correctly this could be the problem. I had similar issues. Improper shifter adjustment can cause internal damage.
C409
Jan 21, 2016 08:29 PM
BHR
Sep 3, 2015 07:51 PM
greenyone
Sep 2, 2015 03:39 PM
db057
Aug 22, 2015 08:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
