Vss questions
Old Aug 2, 2013 | 12:11 AM
xx138xx's Avatar
Car: 94 camaro
Engine: 5.7 KT1
Transmission: 4L60
Axle/Gears: 10 bolt with 3.73
Vss questions
I have an 86 Trans Am. PO did an engine and tranny swap. Well the tranny they put in has a mechanical vss. I need an electrical one. How many pulse would I need 2000 or 4000? What would the part number be? Where could I buy one? Thanks for any help.
Old Aug 2, 2013 | 05:57 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Vss questions
You'll still need to verify the speedo gears are correct for the rear axle reatio & tire size.
But this will work: http://tpiparts.net/inc/sdetail/7586
Old Aug 2, 2013 | 09:38 AM
xx138xx's Avatar
Car: 94 camaro
Engine: 5.7 KT1
Transmission: 4L60
Re: Vss questions
I have seen that one before but it says it wont work with a vss buffer. And my car has a yellow buffer box.
Old Aug 2, 2013 | 10:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Vss questions
Need a 4K PPM magnetic sensor:
http://tpiparts.net/inc/sdetail/7587
RBob.
Old Aug 2, 2013 | 10:39 AM
xx138xx's Avatar
Car: 94 camaro
Engine: 5.7 KT1
Transmission: 4L60
Re: Vss questions
Thanks for the help.
Old Aug 4, 2013 | 10:37 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Vss questions
n/m
Old Aug 4, 2013 | 10:38 PM
John in RI's Avatar
Re: Vss questions
2000 PPM.
Here's a picture of the stock 2000 PPM VSS ( works WITH factory yellow VSS Buffer )
It was used in 85-89 Firebirds, 84-86 Berlinettas and a couple years in the Corvette too I think.
The 90-92 4000PPM unit is not a direct or 'plug and play' part for your 86 !
Old Aug 4, 2013 | 11:59 PM
xx138xx's Avatar
Car: 94 camaro
Engine: 5.7 KT1
Transmission: 4L60
Re: Vss questions
2000 PPM.
Thats what I thought. Do you have the gm part number for that vss. Im having a hard time finding one. I also need a 39 tooth gear.
Old Aug 5, 2013 | 04:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Vss questions
The VSS part I posted can be threaded directly onto the speedometer cable bullet. Only issue may be not enough tunnel clearance, which can be solved by a short length of cable.
RBob.
Old Aug 5, 2013 | 06:18 PM
xx138xx's Avatar
Car: 94 camaro
Engine: 5.7 KT1
Transmission: 4L60
Re: Vss questions
RBob.
You are correct rob. It does take a 4000 ppm. I finaly found my GM service manual and it says its a 4000 ppm to buffer box.
Old Aug 6, 2013 | 10:30 AM
John in RI's Avatar
Re: Vss questions
Ya', I'm an idiot !
The pic I posted IS the right one for your 86,.... 4000PPM TO the buffer. ( it's 2000 PPM OUT to the Cruise and ECM ! )
I've got the factory VSS ( for 34-39 tooth driven gears) and I was able to find the proper 'driven' gear for it too; 39 tooth Brown. ( 17 red and 39 brown for 2.73 gearing )
$80 + shipping; send me a PM for detials if your interested.
Old Aug 8, 2013 | 04:07 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Re: Vss questions
What type of vss did the 93-97 f-bodies use with the T-56? I swapped one into my 87 Trans Am. I'm going to tune my ECM, and there's an option in the program to choose between the factory trans, or you can enter the pulse per rev for the sensor you're using. If I use the stock sensor that came in my T-56, can I just make sure the connecter is right, and enter the correct ppr?
Old Aug 8, 2013 | 04:11 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Vss questions
Assuming your using the 165 ecm there is no ip divisor the buffer is external. You will need to use a Dakota digital sgi-5.
Old Aug 8, 2013 | 05:35 PM
Engine: SBC 350
Re: Vss questions
Of course there isn't. Why would there be? That would be too easy for me.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
