What will faster rear gears do for me?
Old Aug 8, 2013 | 06:20 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I'm still working on the build to replace the 2.8 in my car with a slightly built up 3.4. I'm shooting for 180-190 HP, and from what I understand, that's asy for the 3.4
I'm also thinking of upgrading the rear end of my car from a 3:42 to a 3:08, the same one that came on the V8 5 speed cars. The goal is to drop the highway RPM down below the 2600 at 70MPH that I have now. I'm not sure what the 3:08 would do for me, is there a formula I can use to figure that out?
Old Aug 8, 2013 | 06:35 PM
big gear head's Avatar
Re: What will faster rear gears do for me?
http://www.ringpinion.com/Calculators/Calc_RPM.aspx
Old Aug 8, 2013 | 07:00 PM
58mark's Avatar
Interesting. It gave me 2337. Only a drop of a little more than 200. thought it would be better, but It's still good to know
Old Aug 8, 2013 | 07:04 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The goal is to drop the highway RPM ?
Consider ;
stock a V8 has a LOT more torque ,lower down than a V6 so it can pull a taller ( not faster ) gear.
When you "hot" a engine up you tend to loose bottom end so the engine has to rev higher before it gets into it's working range ,
the main reason you see " low" gears like 3.73 / 4.11 in Hp cars.
Over gear the car ( too tall a rear ) and the engine will be below it's working range and probably use more gas.
Old Aug 8, 2013 | 07:11 PM
58mark's Avatar
Interesting, thanks
Old Aug 8, 2013 | 09:42 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You don't want the 3.08 with the V6. Chevy used the 3.08 with V6 in the early years and corrected their mistake by using primarily the 3.42 gear for V6 after 83. ( many 3.23's out there too ! )
IMO; the 3.42 gear in your car is a GREAT all around gear ratio,.... for V6 or V8 cars. I'd leave it and focus on other priorities - like getting that motor swap finished and the car rolling under it's own power again ! Once your behind the wheel and driving again you can feel out the existing drivetrain ( rather then theory ) and then make a better informed decision about changing the gear / rear.
Old Aug 8, 2013 | 09:48 PM
58mark's Avatar
Actually the original 2.8 is still going very strong. The car runs like brand new, but I've got a 3.4 in my garage that I'm planning on using someday. I'm waiting on a sign that the 2.8 is getting tired, I hate pulling such a good, smooth engine
Old Aug 10, 2013 | 12:32 AM
Eddie1986z28's Avatar
Car: 1986 Iroc Z-28
Engine: 1972 350 4V
Transmission: 1983 T5
Axle/Gears: Stock 2.73
good points.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
