Whining Noise in the rearend ??
I have a 92 RS and it is whining from the rear end like a siren... I checked and replaced the fluid. thewre wasnt much in there a little more then a quart id say. Now it does sound better but it is still making the sound so my question is What could it have damaged for this to still happen? The bearings? Would it be better to replace them or swap out for complete rear end??? thanks...
Re: Whining Noise in the rearend ??
The easiest thing for you to do would probably be to swap the whole rear end. If you don't know how to set up a rear end then you probably don't need to get into it. I would say that the gears are probably worn from low oil. There could be some bearings that are bad, or the pinion nut could have come loose. There is no way of knowing without getting inside it and looking at the parts.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Hard to say without knowing approx location but it could be the pinion bearing or wheel bearings. Also could be the gear set if they are damaged.
Is it leaking out the pinion seal?
okay when I change the fluid the gears looked OK nothing really seem to be too bad or to worn there was no leaking from the cover after I put it back together today there was a little fluid around where the u joint connects to the tranny but I don't know if that's new or old or what it is there's no dripping anywhere when I park itI was thinking that from the low fluid that the bearings were worn and were damaged possibly.
OK. If I do swap it out should I just do the rear end or the whole thing axels and all. And I know I asked before what was compatible but I was wondering if a 10 bolt from a Chevelle or nova say is the same and could I use that
The ONLY rear ends that will fit are 3rd and 4th gen F body rear ends. NOTHING else will work without major work.
You might have a bad pinion bearing or the pinion nut might have got loose.
Thanks a lot ... OK the pinion bearing .. is it a do it yourself project for a novice .. please keep I mind I am very capable and not one of those non mechanically inclined people I just never worked on a rear end before and honestly whatever your answer is I am most likely gonna give it a shot. Lol unless you say you wouldn't do it at home ....thanks again
You will have to remove the axles and then the differential. When you remove the differential there will be a thick shim, somewhere between .220 and .260 inch thick, on each side. Be sure that you do not get them mixed up. Also do not mix up the bearing caps. They must go on EXACTLY the same way that they came off. Then you can remove the pinion. I would not just replace one bearing, I would replace both at the same time. You can get a pinion bearing kit from Randy's Ring & Pinion that will have everything that you need, including the pinion seal, crush spacer, pinion nut and shims. You will have to crush the spacer until you get 20 INCH pounds of preload on the bearings. This takes a bit of work, and you will need a small torque wrench that can read from 0 to 30 inch pounds to measure the preload.
to my Craigslist travels I've come across two rear ends and my question is about compatibility one of them is from a 90 something Impala and the otherfrom the 2002 SS my question is will the impala one fit? it seems to have the same measurements is mine and the other is that the SS is a 2002 and is a disc brake rear end and a six speed so if it will fit what would I have to change
And and from a 1990 s-10 would any of these swap or need modification ..
The '93 to '02 F body rear ends are about 4 inches wider than the '82 to '92 F body rear ends, but they still bolt in. You will have to make adjustments to the wheel backspacing to make the later rear end work in the earlier car.
ok one last question does the kit include all the bearings pinion wheel etc? if not should i do the wheel bearings too. and finally if i wanted to change the gearing now would be the time correct??? and what would I need to change/calibrate if anything thanks alot for the info its been huge...
The pinion bearing kit only has the bearings, seal, nut, spacer, shims. No gear. You have to get the gears in a set. You can not replace the pinion without replacing the ring gear too.
https://www.thirdgen.org/forums/tran...axle-gear.html
Check this out.
Check this out.
ok so replace the gear tooand I was asking about the bearings I guess they are called the wheel/axel bearings the ones on the axel could those be the problem and either way should I replace them as well
You will know if the axle bearings are bad when you pull the axles out. The axle is the inner race for the axle bearing, so if the bearings are worn the axles will also be worn. The rollers in the bearings run directly on the axle shaft. This requires replacing the axles too.
Did you check out the link that I put in post number 14?
ok great so just wait and see when i pull the axels... man you have been an immense help I will probably do it this weekend and if youre interested I ll post and let you know how it went.... thanks alot you probably just saved me $1000-1500. I really cant thank you enough....
Ok I am about to start the bearing work and a friend says he has a rear end from a 98 ss ...Im thinking that is disk brake and 6 speed and also wider like you said. Would it be more practical to swap the rear end I can get it for next to nothing would it work if so what else would i need to do???? brakes etc.
Do a search on here to see pictures of 3rd gen cars with 4th gen rear ends. See if you like the way the tires sit under the car. If you can live with that then swapping the rear end will be the easiest and cheapest way to go.
sjorgens
Oct 1, 2015 07:54 PM
