9-bolt posi into 10-bolt?
Old Sep 20, 2013 | 11:05 PM
mds5's Avatar
Car: 87 I-ROC
Engine: 350TPI
Transmission: WC 5spd
Axle/Gears: factory 3.27?
I have an 88 with a posi in the 9-bolt rear. I want to take the posi out and put it into my 87 iroc 10-bolt rear. I'm not sure if it will work... looking for answers.
Old Sep 20, 2013 | 11:13 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 9-bolt posi into 10-bolt?
will not work-different designs made by two different companys;borg warner made the 9 bolt.
Old Sep 21, 2013 | 07:27 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Nothing is interchangeable between 9 and 10-bolt parts.
Old Sep 21, 2013 | 09:30 AM
big gear head's Avatar
The '87 10 bolt rear end will have 26 spline axles. If you are going to do an upgrade on the rear end then a 28 spline swap would be a good idea. The 7.5 rear end was upgraded to 28 spline axles in '90, so '90 to '92 axles will work with a 28 spline differential. The Eaton Posi, Yukon Dura Grip and Eaton Truetrac are good differentials to use. I recommend any of them, just not the Auburn. Your gear ratio is going to play a part in this too. If you have a 3.08 to 2.14 gear then you will need a 2 series differential. If you have a 3.23 to 4.56 then you will need a 3 series differential. You MUST know what gears you have before buying a differential.
Old Sep 23, 2013 | 11:54 AM
mds5's Avatar
Car: 87 I-ROC
Engine: 350TPI
I not trying to buy a new differential, I am just looking to use the posi unit out of the 9-bolt and change the gears when I put it in the 10-bolt (if it fits). So what you are saying is that I can use the posi unit but I am going to have to change the axles?
Old Sep 23, 2013 | 12:29 PM
No, as others said before, the 9 bolt differential WILL NOT fit in the 10 bolt, no way, no how. You will have to get a 10 bolt differential for your 10 bolt. I was just telling you which 10 bolt differentials will work and giving some sugestions for upgrading the axles at the same time.
Old Sep 23, 2013 | 05:08 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Old Sep 23, 2013 | 05:18 PM
Not even ONE SINGLE PIECE of a 9-bolt will interchange into a 10-bolt. NOT ONE. I don't even think any of the bolts are the same.
The answer unfortunately is NO it will not work. That's about all there is to it.
Old Sep 23, 2013 | 07:17 PM
TxTtopZ's Avatar
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
Rather have the 9 bolt for a street car. Bolt in axles, slightly stronger design, and better yet, you dont have to do any work. lol
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
