Is there any difference between our 700R4's and the 4wd models out of trucks?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Just wondering if there is a difference. Looking at needing a new tranny and lots of truck transmissions for sale but no car ones.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Is there any difference between our 700R4's and the 4wd models out of trucks?
I'm not 100% sure about internally, but externally the tailshafts are completely different. You can change it to match, but you have to take the entire trans apart to do it along with changing the output shaft.
Car: 1984 Trans Am
Thanks. I'm looking for a good core from 88-92 to replace my 84 that is starting to slip.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The guts are the same but the output shaft needs to be swapped
Not a problem if you are going to get it rebuilt but,
if you are using it for a core ,check the rebuilder will accept a 4wd version in exchange for the reg version
The 4 WD models use the heavy duty K case which uses a rigid aluminum dust cover to keep the bdllhousing from cracking. Itll still fit but you can't use the original sheet metal cover
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
find a 1987 or later core.most of the 700r4 design flaws fixed by then.
